This was the first test with the VW GOL cooling system.
Second test with the GOL system after a vane was added to the left side. I shut it down early before we damaged the engine
This one is a test with the center mounted style cooling fan with a stock drive ratio. Notice the cylinders run in temps as pairs, this trend follows all systems EXCEPT stock doghouse.
This is the first run with the TI DTM, just as Joe designed it. Stock drive ratio
This one is a Stock doghouse shroud with stock drive ratio. Notice the hotter #1 and #2 cylinders, but how even the cylinders run as pairs. this will not be seen with any other system, but its what our goal is. We WILL get overall temperatures down and keep them even!
This one is the best graph from the TI DTM before we saw that we needed to do some more design work. As you can see we have made some headway from the first run. I have some ideas that we are going to employ to get the overall temps down, then we'll try again.
