Type I DTM- It's Perfected!!!!!
bugsterkafer
Post by bugsterkafer »
:?: but there is no thermostat am I right?so the cylinders are always being cooled? do you think it could work too, in a small city with a lot of traffic jam?
because here in winter it's often like below 0 temp, so if the engine is cooled when I have just started it.... and when I'm waiting for 5 or 10 minutes on the 1st light.... do you think the results could be good though?
:roll:
Post by MASSIVE TYPE IV »
If the climate is that cool the benefits of the shroud may not be that much for you.
dstar
Post by dstar »
bugsterkafer wrote::?: but there is no thermostat am I right?so the cylinders are always being cooled? do you think it could work too, in a small city with a lot of traffic jam?
:roll:
Sounds like you need to invest in CHROME valve covers,
to hold the heat IN, and not worry about increasing the
cooling ability of your bug!
:lol:
Don
bugsterkafer
thanks Don I did not think about it! :twisted: damn chrome tins won't see my engine:never! :wink: :D
They were part of a cold weather kit that VW used on Arctic engines... Even a chrome sump plate!
bugsterkafer
yes I saw this kit on a 67' bug from Finland it's very interesting:you give electricity and it warms oil before you start your engine
Thanks fro your honesty Jake you could have told me it was possible to use your shroud , like some guys would have dared to!
slackin' at work
Post by slackin' at work »
jake, I didn't see this on your site... but how wide of an engine can the t1 dtm cover? Im running a 2332 and it comes in just under .5 inches wider than stock.
thanks.
glad to see you finally got it.
-chris
Guest
Post by Guest »
slackin' at work wrote:jake, I didn't see this on your site... but how wide of an engine can the t1 dtm cover? Im running a 2332 and it comes in just under .5 inches wider than stock.
thanks.
-chris
That's only .25 inch on each side.
They sell block off plates for that in the VW Rags........
click on the Moore's parts banner at the top!
Don
I have .220 shims on the 2332 test engine and it fits fine. Just required a bit more trimming around the manifolds.
bugsterkafer
little missunderstood guys: I was talkin' about 0 Celsius degrees... same answer Jake??? :roll:
Locked
