Page 3 of 4
Posted: Mon Jan 17, 2005 6:01 am
by LouisCypher
Hi,
and would the 2.0L plenum, TB, and runners be big enough if they were used in combination with another EFI system, e. g. from a T3 vanagon (DigiJet)?
Greetings,
Louis
Posted: Mon Jan 17, 2005 6:12 am
by LouisCypher
big enough. let's say, to produce 130 HP from a 2.0L engine with a mild cam, some porting and a higher CR?
Posted: Mon Jan 17, 2005 9:59 am
by Bleyseng
I think you are going to have to step up to a programable EFI like kitcarson or Megasquirt, Haltech etc.
Geoff
Posted: Mon Jan 17, 2005 10:30 am
by LouisCypher
Ok, then assuming that everything is programable, would the TB, plenum and runners from a stock 2.0L 914 engine flow enough air in order for the engine to produce 130 HP? Even more?
Louis
Posted: Mon Jan 17, 2005 10:32 am
by MASSIVE TYPE IV
..........Thats according to how the rest of the engine was set up. Engine size alone means nothing to power output!
Posted: Mon Jan 17, 2005 11:09 am
by LouisCypher
Let me put it another way:
Suppose you want to build a TIV engine for a 914 and want to keep at least the stock TB, plenum and runners. When will these parts start to be a restriction (in displacement or HP) when otherwise there is NO restriction. And please no turbos or things like that.
Louis
Posted: Mon Jan 17, 2005 1:14 pm
by Guest
LouisCypher wrote:Let me put it another way:
Louis
The simulations that I ran in the past with Engine Analyzer showed (if I remember right) that the stock d-jet intake runners do limit hp considerably compared to what can be achieved with an IR system. I think that was true for both a 2056 and a 2270.
Posted: Mon Jan 17, 2005 4:42 pm
by Bleyseng
I will be playing with these questions soon. Another 914 guy is aready trying to make a 2270 work with the 2.0L stuff with MegaS. Its runs now but is it tuneable? It looks like the runners are too long for high rpm hp but will a larger plenum/shorter runners work. The cam and exhaust flow is key IMHO.
Geoff
Posted: Tue Jan 18, 2005 3:41 am
by LouisCypher
Hi,
but as far as I have understood from
http://www.aircooledtechnology.com/912e_kitcarlson.htm,
Jake's 912E with a 2563 cc engine makes nearly 200 HP, and it is equipped with the original plenum and runners!? Or am I wrong?
Louis
Posted: Tue Jan 18, 2005 7:28 am
by MASSIVE TYPE IV
Um....
My 912E is only a 2056 with 120HP on a good day, before it racked up about 75000 miles in 2.5 years..
IMHO I/R is always gonna make more power, but a Plenum based system will be smoother at lower revs..
Posted: Tue Jan 18, 2005 7:39 am
by LouisCypher
Oh, so the diagram on the tope of the page does not belong to the car shown below......
Posted: Tue Jan 18, 2005 9:12 am
by MASSIVE TYPE IV
huh, what page????
Posted: Tue Jan 18, 2005 9:21 am
by LouisCypher
as mentioned above, repeated for your convenience here
http://www.aircooledtechnology.com/912e_kitcarlson.htm[/url]
Posted: Tue Jan 18, 2005 9:48 am
by MASSIVE TYPE IV
Never seen that before! We'll change that graph!
That graph is for the 2563 engine located on the pages before.... Here
http://www.aircooledtechnology.com/kitcarlson.htm
Sorry for the confusion, as you can read here my 912E has a 2056cc engine..
http://www.aircooledtechnology.com/about_jake_cars.htm
Posted: Tue Jan 18, 2005 10:56 am
by LouisCypher
Tank you, Jake, things are somewhat clearer now.
