2450 (78mm x 100mm) engine build
Eddie010
Re: 2450 (78mm x 100mm) engine build
Post by Eddie010 »
Wally wrote: ↑Sat Oct 04, 2025 12:49 am Probably not many people that have that exact combo running before you to share that..
You can call CSP as they sell the Wasp.
Or just try it and if it doesn’t fit, reposition the oil filter with an adapter.
If it only just touches a little, there are many different oil filters, some are way smaller in diameter I know from experience 😉
Yeah, I think you are right.
Maybe give csp a call than.
Thanks for the reply walter.
Regards eddie
Can also use a remote filter with a proper oil thermostat.... spin on adapter or simply fab a simple outlet for the filter location from some thick aluminum scrap and a barb or swagelok fitting. That way is usually easiest to run cooler as well. Return oil to main oil gallery by the pulley.
If you have one of those remote line cooler mount adapters it's trivial to drill and turn into a loopback so you still have the stock overpressure bypass working. Best use for them. CSP also used to sell a low profile loopback for the oil cooler mount.
Eddie010
Post by Eddie010 »
Got the engine out, to mount the remmele heads.
Don t think I showed how the hot air from the type 4 cooler leaves the engine compartment.
Bruce.m
Post by Bruce.m »
Nice. I might copy that
Eddie010
Post by Eddie010 »
Can I ask a suspension related question.
I am also converting the irs springplates for 944 adjustable ones.
did a muck up, but I am not yet satisfied.
Placed a 5mm ring (washer) to the inner side off the torsion plate then placed the the inner rubber to clearance
the adjusting (heigth) bolts of the 944 sprng plates.. They still rub a bit against the torsion tower. Did you guys clear the adjusting bolts on the 944 plates,
to give a bit more clearance?
The second question is did you place an extra pivot ring on the inside of the trailing arm, (on the chassis side) to get the trailing arm a bit more out,
so that it better fits the 944 spring plate.. To accommodate the 5mm washer on the spring plate..
I think otherwise it looks like I have to bent the spring plate to much to match it to the trailing arm.
Hope you guys can help.
Regards Eddie
Has been awhile since i looked, went with the early turbo alloy arms on my square, made sure to put any nut I could on the inside, but do not recall any obvious way to assemble it "wrong". The adjustable spring plates were worth it in my case as I made up some coil overs from Bilstein and Fox parts, as well ad KYB bits abused as external resis for the front, gave me a shorter shock and same travel. My torsion bars are all mounted "unloaded" at rest. (t3 front bars are splined too)
The T3 also has fabricated sheet metal shock towers etc, so not really same as T1 except from 20 feet.
I do recall doing some plasma cutter work for bolt and access clearance.
On a T1 you might be ahead with the adjustable arms from EMPI et al...
The the alloy trailing arms provided ~no benefit, other than having mounts for the 911 style parking brakes and Brembo calipers. (The 911 parking brakes can be added on the steel arms too so you don't have to fight a ratcheting-somewhat self adjusting parking brake setup)
Bruce.m
Post by Bruce.m »
I did the research on this years ago. Unfortunately most of that knowledge has faded with time. I remember the inner spring plate bush needed swapped from 944 part to beetle part, with a spacer. Then the spring plate adjuster nuts needed thinning down, plus a bit of chassis grinding to make it clear. A bit off here & there. Sounds like you have the spacer mod but are left needing the clearance grinding. The outer retainer can be cut down 944 part or the dual plate beetle version (has spacers as stock), plus maybe some extra spacers.
All of that made me decide to keep the beetle spring plates but I did clearance one of the mounting holes with a round file, so I could use the 944 camber adjuster / sway bar mount. So although the ride height can’t be fine adjusted, i can adjust the camber & use a 944 rear sway bar.
Eddie010
Post by Eddie010 »
Thanks for that info guys.
Will look into this.
Regards Eddie
Eddie010
Post by Eddie010 »
Small update, machined down the adjusting bolt 0.5mm and grinded the locking bolt a bit down. It now clears the the inner part of the shock tower.
So seem to functiun like this. Hope the tow in/out is adjustable a bit.
Otherwise I have to shim the trailing arm with a shim.
Eddie010
Post by Eddie010 »
Getting further with the engine for this season.
Final set up to my goal.
Wasp header on a type 4 engine :D
Small mods needed, oilfilter does not fit anymore and oilfilling pipe has to be adjusted a bit.
Is there a oilfilter move kit or something available?
Thanks to JPM/CSP vw
Bruce.m
Post by Bruce.m »
Nice :)
Options for the filter, i can think of
1) mocal filter relocation kit (blocks off tge filter mount & has out & return port. Bit chunky though.
2) full flow oil pump cover with out & return ports.
3) full flow oil pump out, return via cut down stock oil filtermount or direct to tapped case.
Eddie010
Post by Eddie010 »
Short block is back together.
On to the cilinder and heads.
Eddie010
Post by Eddie010 »
This is a bit how it should be.
Eddie010
Post by Eddie010 »
Trying to fix some problems mounting a Wasp on a type 4.
Found an oilfilter take off that fits.
And modified the oilfiller tube to clear the exhaust.
Need to weld a plate to it.
Bruce.m
Post by Bruce.m »
Tight on the filler. I’d perhaps adapt the breather on the alternator stand into a breather/ filler instead?
Have you replaced the oil relief valve piston& spring with an oil temp sender?
