200hp 1200DP Turbo 'Challenger motor'
MegaRookie
Re: 200hp 1200DP Turbo 'Challenger motor'
Post by MegaRookie »
Very nice results Walter! Is the t4 in the car back already? I am curious what your next challenge with the 1200 will be. I guess this will not be the end of the story, or is it? ;-)
Enjoy!
Wally
Post by Wally »
The 1200 is indeed already out, but the T4 not back in atm.
No, I indeed still have some plans for the 1200, as some parts and build decisions were not optimal at all.. 😎
my_medusa
Post by my_medusa »
Cograts, it was an amazing event. And we germans are very very jealouse what you guys in netherlands are allowed to create "street legal". Walter finaly did it with an ordinary w110 cam 😁. My personal hero is also hendrik with his fiat 850, amazing car and build and he in person also. Much cudos. And with the 3.44 final drive plus the compound it is very quiet, builds boost smooth and early. I drove with him and he has 25psi around 2700rpm. When he gets the boost rise better in controll its a "minimum" 360nm 300hp engine with a powerband (under 2500-6000+)rpm. Haha. And that in a fiat850😎😎😎 ultimate sleeper!
brewsy
Post by brewsy »
Wally wrote: Sat Aug 28, 2021 1:45 pm Guys, I did it! :D :D :D
After about 10 years since I took part in the 1200 Challenge, I finally achieved (and as the first it seemed) the 200 hp barrier from the VW 1200 engine at 1200cc (well, actually 1208cc as I needed to get a 0,50mm oversize because my base block had water in some barrels..)
I cant believe that I've only just seen this Wally.
CONGRATULATIONS... That's awesome work...
Cheers
Wally
Post by Wally »
Hey Marc,
Tnx!
I think that next year a few will attempt to break the n/a record of 100,64 hp.
That will be a lot more work, but its fun trying.
This will be the lay-out for my effort:
But as its not boosted, this won’t be covered here.
brewsy
Post by brewsy »
Wally wrote: Mon Nov 08, 2021 1:15 pm Hey Marc,
Tnx!
Always somethng new Wally :D :lol:
VERY interested in this setup too.. Please let us know where/if you will cover that? Another forum?
Interesting you are going 'straight port' with the manifolds too. Have you seen Peter Shattocks + JPM motor? The TB's actually stick out the side of the engine compartment!
Is that a cam position sensor coiled up around the dipstick? :wink:
Cheers
Wally
Post by Wally »
No, its just the hidden sensor for the 24-1 toothed wheel behind the pulley. VWspeedshop makes these, they are awesome: I run with zero errors on these set-ups (most usually run with a few or a dozen or so missed signals).
Sequential doesn't give more hp imo, so not needed at this level.
I first saw a straight manifold at/from a friend of mine (who flow benched the first Apfelbeck head) at around 2004 and the idea stayed with me. JPM indeed also used it. As I got these manifolds for free (and they could be reversed, not designed for it) from a custom program (one-offs), I thought to try that old idea. These 1200 engines with there extremely small bores and consequently very shrouded valves, need all the help they can get..
Plus these manifolds were for a DCNF pattern, so very close spacing, even more straight! Fortunately Jenvey still makes a set, but those were not for free..
But I'am not busy on the engine yet, will let you know when I do ;-)
Kalle
Post by Kalle »
Ah... refreshing to see that you are not running out of motivation Wally. 100.64 should be reachable also with ordinary pump fuel Shell 98 or 99 octane. There is 200+hp NA 1.6 liters our there so 100+ from a 1.2..... just sayin.
-K-
Wally
Post by Wally »
Cheers Kalle!
Yeah, you would think so right?
What started as ‘sweet the Floor’ engines, gradually got more and more custom though haha!
Kalle
Post by Kalle »
Wally wrote: Sun Nov 14, 2021 1:56 am What started as ‘sweet the Floor’ engines, gradually got more and more custom though haha!
Tell me about it.... but that is what is called a hobby. Having a hobby is what saves most marriages so in other words.. you are spending your time and efforts where it counts.
-K-
my_medusa
Post by my_medusa »
Wally wrote: Thu Nov 11, 2021 6:10 am
The manifolds are amazing, you was faster than me to get them. But i would not say, that this is the bottleneck in 1200cc tuning. The problem is compression ratio (bmap) and nobody is using the potential of the 1300 heads and 77mm bore in rpm. There are just 3 main factors for hp. Displacment (fixed 1200cc), rpm and bmap(compression ratio.... Sure reflection, fuel and ignition are also important. The 77bore and 1300 heads are proven to 125hp at 7300 rpm in 1300cc that would be around 7800rpm with the 64mm crank. And to reach that you need alot of cam and the matching compression.
Downside it's at the end a low torque engine because of the small displacement.
