At least he didn't wipe out the shock or the axle. Arms are easy to build( for some people).CopperBaja wrote:That was some nasty carnage.
Poor Man 4 seater.
- baja5
Re: Poor Man 4 seater.
- Getrdone
Yeah, it goes inside and ties to the cage (main hoop). And yeah, B5 towing and oral service!bajaherbie wrote:nice double shear on the pivots... i presume that it is tied to the cage?
and why did you load it on a trailer to load it in a 'hauler?
- takotruckin
Hey Getrdone, I'm digging your new avatar
- baja5
takotruckin wrote:Hey Getrdone, I'm digging your new avatar
Me too, can't wait to be driving it.
- Getrdone
Blue is well. I have been doing all the fluids and grease for the nite run and next season. I have been having a hard time getting the cash for my new shop slab so Blue may be for sale after the nite run. I would really like to keep it for the next season, and hopefully my new homeowner rebate will help the slab. Kind of in the air. I have been welding on the Things and should have some update on that soon. I am just getting used to garage fabin again. If anyone needs welding speak up, I would love to take your money. I almost applied for a nite shift MIG welding stainless! I figure I'll weld up up a bunch of 4130 beams and sell them on the net before I work for the Man again.
On a side note, I quit baby footing the motor and found it actually makes some strong power up top. Kinda of suprised me.
P.sss. when I see your screen name I always picture this.
Michael "Mike" Wazowski
- KBWAKESK8
Thats funny
That is the color i want to pant my 4 seater.
- motorbreath53
We may be able to discuss some TIG welding for hire on my lower arms and spindles... depending on how proud of your work you are..
- Getrdone
Pay and welding, anytime! Proud, only if someone else is happy with the finished product.
- anzan
I've seen that welding and it's AAA! Looks like a machine did it!motorbreath53 wrote:We may be able to discuss some TIG welding for hire on my lower arms and spindles... depending on how proud of your work you are..
- CopperBaja
I need a skid plate built for me.
....and need to tie my cage into the horns....
- Punchdrunk Monkey
I might need an oil pan welded. Looks like when the pan was welded they didn't use any filler material and now it's starting to crack. I've got a TIG but now sure if I would make things worse
- Getrdone
No problem I'll give you a call, the key is to remove all oil from it. I use a little heat from my little propane torch to open the pores and a special degreaser for spaceships (post label later). Aluminum loves to hide microscopic oils in it that love to show up just as your coming to the end of the weld. Cooper, you have a skidplate for the nite run though right?
- CopperBaja
Not yet....at present time, I don't have brakes either, nor do I know if it will fit in the trailer.Getrdone wrote:Cooper, you have a skidplate for the nite run though right?
I have a street sign that Rick gave me a while back that I was thinking of cutting up...and getting a 2nd piece, but am wondering if a single piece skidplate would be better.
- Punchdrunk Monkey
Thanks, right now I'm working on getting the motor dyno'ed. After that will be the oil pan, then cv's. I'll let you know when I get ready to pull the pan off.
