Page 4 of 82
Posted: Fri Feb 16, 2007 12:58 pm
by runslikeapenguin
whats your budget? i know of a few places where you can pick up a poly tank with foam in it for around $120, or less if you get a knock off.
Posted: Fri Feb 16, 2007 1:29 pm
by rickosuave1987
runslikeapenguin wrote:whats your budget? i know of a few places where you can pick up a poly tank with foam in it for around $120, or less if you get a knock off.
i was hoping to not spend much, but around 120 seems to be a good deal with foam. where can you find them for that?
Posted: Fri Feb 16, 2007 7:55 pm
by runslikeapenguin
i was looking through a JAZ catalogue and i saw a few in the 10-12 gallon range. i would start there, also summit racing offered a wide variety of fuel cells for cars
Posted: Mon Feb 19, 2007 1:45 pm
by rickosuave1987
Well I was sort of rained out earlier today, but I did get a little cutting in.
I only really cut more off of the nose, I dont think I need to cut the entire front end off just to fit the new front end. It is a little tweaked and doesnt sit flat so I dont want to cut any more until I get some fasters to hold the center so I can mark of the sides where I want to cut.
But this is the general idea.
I was suprised the fenders actually follow the contours of the original fenderwells, eve though it doesnt look like it in the pic, its just cause the fiberglass is bent.
Also had a package waiting for me when I got home from breakfast, light buckets from mooreparts, definitly worth the $18 bucks each since they came with pigtails (and of course the chrome 8) )
Posted: Mon Feb 19, 2007 6:34 pm
by rickosuave1987
I got some tabs welded onto the front bumper for the headlights. I decided it was the best look that I liked that would not inhibit tire clearance.
A friend of a friend is supposed to be lending me a tubing bender soon. So I might just fab up my own front bumper. We will wait and see how funds are doing.
Posted: Sun Feb 25, 2007 8:42 pm
by rickosuave1987
Ok. So I got my Dzus fastners in the mail, but havnt had time to install them. Anyone have an idea of how to make a front mount for the hood? How have others done it? Pictures would be most appreciated.
Posted: Tue Mar 06, 2007 9:39 am
by CopperBaja
Is that a tilt-front or rear?
Posted: Tue Mar 06, 2007 10:01 am
by rickosuave1987
CopperBaja wrote:Is that a tilt-front or rear?
No its not a tilt front end. I need to make some brackets to attach it to the body.
Posted: Tue Mar 06, 2007 5:07 pm
by bajaherbie
i don't have a photo but mine is held on in the front with two ordinary hood pins (mounted to front bumper/skidplate) and two jeep-style fasteners on the rear sides. i could take a pic tomorrow, pm me if you need it...
Posted: Tue Mar 06, 2007 5:10 pm
by bajaherbie
found this pic.. the pins are chrome and mounted horizontal in the 1" tubing...
Posted: Sat Mar 17, 2007 10:25 pm
by rickosuave1987
All right. Spent some of today working on the car. Got the base for the fuel cell made, took out the passenger seat and took out some more interior.
The base.
And no, I was not welding on the fuel cell. :roll:
Tacked together:
How its going to mount in the car
Also got an electric fuel pump. Called McKenzies, they didnt have any in stock so I went to the local place and picked one up that doesnt need an external pressure regulator.
Also found this under the carpet. Was kind of suprised I never noticed it from the outside.
Posted: Sun Mar 18, 2007 12:16 am
by crane550
Thats fairly typical. One of mine looked worse then that in the same spot. Usually under the battery is the worst. I got pretty lucky, the floorpans in my current project are near perfect. The good news is all it takes is a little sheet metal, looks like you got the tools you need. :D (something I DONT have! ) :oops:
Posted: Sun Mar 18, 2007 6:32 am
by Getrdone
Rico, don't mount your glass like mine. The pins are on a compound angle and it is a royal pain. I also think the PO cut off too much on the edges (front to rear). I am going to try and get something done by next weekend. Keep up he good work!
Maybe a single mount like El Robi sicne your glass is so small
Posted: Sun Mar 18, 2007 9:46 pm
by rickosuave1987
Still havnt gotten a chance to mount the 'glass up :(
BUT.....I did do something big today.
Installed a new engine! :D Yup. For working on my uncles chop top, he is paying me with an engine he had and was trying to sell.
Its nothing big, but its better than my little tired old 1600. Its a 1600 DP with a pict 34 carb. It was built and put in a car that was driven maybe 500 miles. It has a remote cooler, remote filter and super cool tins. It does have bypass and not full flow, but for the price Im not complaining. Also came wih a kennedy stage 2 pressure plate 8)
I had never pulled or installed an engine before and I did both in under 20 minutes 8) :lol:
Posted: Sun Mar 18, 2007 9:57 pm
by mike@crosbys
so you ready for ocotillo? :D
