Tanks!1 HOT VW GP wrote:Hi Rydh
The Quality of your work are Excellent
A question or 2 if I may
I dont see you mentioned after market EFI are you still using the VW DJ system![]()
Pierre
I use a slightly modified DJ system, larger injectors volvo 218cc in the custom fuelrails, a 1:1,2 progressive Fuelpressureregulator from malpassi.
I have adjusted the spring in the stock AFM by tension it five clicks and i run about 4,5bars of fuelpressure.
I runs a bit to ritch when its cold but after just 500meters driving it works fine.
The new best ET from last week is 13.19s on 402m and 8.29 on 201m. This time drove on M/T et streets
//Rydh
