My build up
ToRy 70
Post by ToRy 70 »
Are you going to watercool the turbo?
64bug
Post by 64bug »
ToRy 70 wrote:Are you going to watercool the turbo?
nope.
Matt Davis
Post by Matt Davis »
my65bug wrote:
Matt Davis wrote:
my65bug wrote:
64bug wrote:
my65bug wrote:Very nice work.
This will all fit in the engine bay?
How much does marty charge for that intake setup?
Thanks, And yes anything will "fit" if i make it fit... Its not all going to be in the bay.
You can ask Marty that question. You get what you pay for.
Oh I am sure it wont be cheap but it is so purdy....
I have a 65 I am doing so I will keep my eyes on this post.
Hope he gives you a good price on that car you're doing.
I sure hope so... this guy Matt and Dave are doing the work. Its coming together so I just need motor ideas now.
Going turbo?
64bug
Post by 64bug »
header came today. Fits amazing! (Thanks Marty!)
Almost time to mock it in the car, from there i can tack up the exhaust and send back to Marty to Tig up and coat.
iswinkels
Post by iswinkels »
Looks Sweet!
Are you going to run that large pully with the porsche fan? I ran a normal power pully size on my 2332 turbo with an 11 blade fan and its temps were very stable. Oil temps around the 170-180 mark.
64bug
Post by 64bug »
Nope just for mock up.
MarioVelotta
Post by MarioVelotta »
Is that a burns collector? Looks real good..
[email protected]
Marty
Post by Marty »
MarioVelotta wrote:Is that a burns collector? Looks real good..
It starts life as an S&S, and then 1 hour of "fine tuning" and it looks like that.
red74super
Post by red74super »
so what are you doing for the turbo drain, I don't quite see how you are going to run it.
other than running a scavenge pump somehow? just wondering.
your new setup is SICK :twisted: just make sure you save some money for new tires
ToRy 70
Post by ToRy 70 »
Make sure you put some sharpie marks on the pipes, just in case the tacks break. I learned this when I worked on my car and header in seperate places, lol.
Are you going to muffle?
And a question for Marty: when working with intake plumbing, do you prefer steel or aluminum? Also I assume the ceramic coating is so that heat soak is minimized?
64bug
Post by 64bug »
red74super wrote:so what are you doing for the turbo drain, I don't quite see how you are going to run it.
Ya pump it back to the case.
And tory, no muffler for now. I like em' loud. but we'll see.
Marty
Post by Marty »
ToRy 70 wrote:Make sure you put some sharpie marks on the pipes, just in case the tacks break. I learned this when I worked on my car and header in seperate places, lol.
I prefer steel, mostly due to the flexibility of fabrication and stregnth.
Yes I like to coat everything I can to control heat.
Matt Davis
but why silver? you and i both know it cooks off w/ turbo use. black ceramic is rated 2-300*degs higher depending on mfg of coating.
i wont use silver on any turbo items unless it's intake or the customer HAS to have it. Do you have some secret silver you use?
Marty
Post by Marty »
Because thats what they want. It will dull at tight bends and at the collector under "higher" boost applications, but...... I have not had many people want to black.
They think it looks too much like rattle can.
The intake NEVER dulls.
They can have it pink for all I care.
turbo54
Post by turbo54 »
is there a problem with NOT watercooling the turbo?
Obviously they were designed for water, I am trying to work out a little loop with radiator for just te turbo (GT2871). Does it really need it? Marty?
T54
