Still woriking on the pump system, the waterpump is from a Opel Omega A.
Radiator mounted above tranny:
Paul, the turbo only needs the water cooling connected to the housing is you are shutting off hot, and even then it only prevents coking.Paul H wrote:We just ran this off the shelf charge cooler and it works fine to a point
but over a 1/4 mile run starting with 26 degree AIT temps at 3/4 track temps are over 60 degree's and rising. The system including the header tank
holds over 2 gallon of water and it's mad hot back at the pits. The water system also cools the turbo housing which obviously adds plenty of heat. These systems definately work well but only as good as the radiator.We'll be adding a larger header tank in ally and another radiator (oil cooler) to keep temps below 60degree all the way
