VW Gear Box Codes & Gear Ratio's
rsw
Re: VW Gear Box Codes & Gear Ratio's
Post by rsw »
Bruce2 wrote:It is an IRS gearbox that has been converted to swing axle.
I am very new to the VW world and am learning this slowly. I just got this back in a email from the guy I bought the trike from. Does what he is saying make since?
The trans came from a guy in Olka that rebuilds them with the 082 gear from a bus 4th gear its called a freeway flyer trans Higher gears so you can drive faster then 55-60. Trans is out of a 68 VW bug.
Bruce2
Post by Bruce2 »
There's the proof. The gearbox was rebuilt. At the time the .82 was installed, it was converted to swing axle.
The final two points are wrong. With stock gears, 70-75 is not a problem.
The trans is NOT from any 68 Beetle. It is from a 69-72 Beetle.
rsw
Post by rsw »
Thank you Bruce2, he sent me that after I posted the question. So if I ever need to replace the transaxle, what all cases will work with a type 1 torsion tube. I understand that any IRS will have to be converted to a swing axle.
Typ 11 Beetle
Post by Typ 11 Beetle »
Need to know more about a GA Gearbox , out of a 181 from 74.
Is it with LS Diff?
ledsel
Post by ledsel »
Wish to know what year this tranny is. Cast no. is 113-301-103. Ser. no. is 6724692, there are no letters and it is a swing axle. 6 volt starter bearing hole. No back up light switch. No input shaft sleave.
Bruce2
Post by Bruce2 »
There are no letter codes because it was built at a time when there was only one configuration.
4.37 R&P
3.80
2.06
1.32
.89
Post by Marc »
ledsel wrote:Wish to know what year this tranny is...
I'd say 1964.
ledsel
Post by ledsel »
Thank you guys, So is 1rst gear overdrive?
Post by Marc »
Fourth is overdrive (.89:1) as it is in all normal/stock Type I/II/III transmissions.
ledsel
Post by ledsel »
I didn't know that. Thanks.
Bruce2
Post by Bruce2 »
Marc wrote:Fourth is overdrive (.89:1) as it is in all normal/stock Type I/II/III transmissions.
Except for the VW Hormiga. :wink:
It had a 1.04 top gear.
sideshow
Post by sideshow »
And don't forget .93 and .82 are just as normal if not more normal than Hormiga.
Post by Marc »
sideshow wrote:And don't forget .93 and .82 are just as normal if not more normal than Hormiga.
OK, that was a poor choice of wording, I meant that overdrive was universal, not the .89 ratio in particular.
.82 is found in most II transmissions.
.93 is found in most late I (such as the AT)
There's also a .88 found in the later AH transmissions and `Ghias.
I thought "normal/stock Type I/II/III" would've been construed to exclude the Hormiga and its cousins.
RHough
Post by RHough »
This is one of the nicest gear ratio calculators I've found: http://www.teammfactory.com/gear-calculator
It allows you to input 2 tire/final drive/ratio combinations and compare them. Most of the other calculators I've seen only do one at a time.
Randy
vwbilly
Post by vwbilly »
Yes I like that one too I've used it many times
