Page 4 of 37
Re: Lord Bajamungus build
Posted: Mon Feb 22, 2010 4:23 pm
by Big Dave
1966bajabug wrote:looking good kyle cant wait to see you car at 5-mile.
I've been all over the place here in Utah, but I haven't been there. The one Saturday my friends went, I had to work
We will have to meet up down there in a few weeks. I will need to do some test and tune once I get my heap running again
Posted: Mon Feb 22, 2010 6:21 pm
by 1966bajabug
well Dave keep us informed, were always up for a desert trip! just remember to go easy on the gas pedal for all us VW powered baja's.
P.S. May 1st is BOR's first race of the season would love to have more support for BRAT racing and more chase crew.
Posted: Mon Feb 22, 2010 8:49 pm
by Qurtys Lyn
1966bajabug wrote:well Dave keep us informed, were always up for a desert trip! just remember to go easy on the gas pedal for all us VW powered baja's.
And more Baja's! Slap some numbers on that thing Big Dave and call it a Class 5!
We'll chase for you!
(As long as you don't have a turbo...)
Posted: Sun Feb 28, 2010 8:57 am
by kyle_pc_75
Posted: Sun Feb 28, 2010 9:11 am
by Lotrat
that's the way I ran mine...
Posted: Sun Feb 28, 2010 9:53 am
by ntsqd
I don't know about the Bug fuel tank senders, but the Bus senders are either a different resistance or use a calibrated resistance wire. All that I can tell you is using a bug sender with a bus gauge results in wacky readings. Just a heads-up should you run into that.
I gave up and built a probe from a piece of 1/4" dowel stock.
Posted: Sun Feb 28, 2010 1:40 pm
by kyle_pc_75
ntsqd wrote:I don't know about the Bug fuel tank senders, but the Bus senders are either a different resistance or use a calibrated resistance wire. All that I can tell you is using a bug sender with a bus gauge results in wacky readings. Just a heads-up should you run into that.
What do you mean? Does mine look like a Bus sender, or do you mean I need a special type of wire run to the gauge? It always worked before with regular wire, though I never trusted it as it bounced around quite a bit. I'm hoping nice new wire will fix that. Thanks for the heads up.
Kyle
Posted: Sun Feb 28, 2010 4:00 pm
by ntsqd
I put a bus gauge set in the buggy's dash and the bug sender did not work with the bus gauge. Don't recall which way it went, but they didn't play well together.
Posted: Sun Feb 28, 2010 4:30 pm
by kyle_pc_75
Gotcha ntsqd...pretty sure all my stuff is bug, though. Lotrat, I just don't trust the zipties getting baked and brittle in the sun, so I'm gonna work out something better.
Well, I got a bit more done before the big hockey game started and I had a few beers. I don't drink and wrench.
Homemade "industrial tins"; not pretty but I'm in a hurry to get this car on the road:
Zenith installed with super-duper preheat. I'm taking the oil breather line to the carb, as well as two lines from heated post-cylinder air. It iced up bad on wet, cold days.
I'm excited. This gives me three weeks of tuning time before our Utah Desert Clean Up and the Rally Cross.
Kyle
Re: Lord Bajamungus build - IT'S ALIVE!!!!!
Posted: Tue Mar 02, 2010 4:46 pm
by kyle_pc_75
Sprayed a little starter fluid down it's throat, turned the key, and it started right up! I'm stoked.
I checked all the circuits, and almost everything works!
Two things I screwed up:
- Forgot to wire the turn signal switch into the L and R circuits, no biggie.
- Reversed the wiring on the backup light and license plate light, doh! Luckily they're right on top of one another, so that's an easy fix as well.
I registered for Rally Cross last night, so I need to get it dialed in soon! Two and a half weeks to go.
Kyle
Posted: Tue Mar 02, 2010 4:51 pm
by Lotrat
It's awesome when they come to life. Congrats!
Posted: Tue Mar 02, 2010 4:56 pm
by Big Dave
Good deal! Love hearing them come to life!
Where is the rally cross at?
Posted: Tue Mar 02, 2010 4:58 pm
by Joxracing
satisfing isnt it?
Posted: Tue Mar 02, 2010 5:25 pm
by kyle_pc_75
It feels awesome, thanks!
Dave, the rally cross is at Miller Motorsports Park in Tooele. I'm going with a few friends, it'd be great if you could make it out as well. I found out about it through this thread:
http://shoptalkforums.com/viewtopic.php?f=28&t=129857
Patrick ran his Baja there last month. I was inspired!
Kyle
Posted: Tue Mar 02, 2010 6:27 pm
by Big Dave
I might just have to come check it out. I don't see anything about it on the Miller motorsports park website though.
What time of day does it take place, and how much are tickets for spectators?
