my 65
Wally
Re: my 65
Post by Wally »
panel wrote:What's the deal with the oil heaters?
His engine has such tight clearences that he needs to pre-heat the engine before it can be started aka F1-style :mrgreen:
Sorry Andy, couldn't resist :lol:
fast65
Re: my 65
Post by fast65 »
its also for when i run the car on meth to boil out any contamination :)
i got a whole day in the workshop to and ive nearly completed one A Arm
it all started here
then two
cutting up the CDS tube
and one nearly done
thast the easy bit ive got to make the other exactly the same no thats the challenge
cheers andy
fast65
Re: my 65
Post by fast65 »
well i went out today to get some printer ink and fell into the workshop :lol:
this is how they will fit
TIGed up the bosses didnt turn out too bad i dont do much welding
cheers andy
shag55
Re: my 65
Post by shag55 »
Hey Andy, looks like you are going micro stubs. I should have gone that route on my notch. They are much stronger and less flex. Did you choose your rim already? On your arm you should add your outer arm once you have it all together and figure out backspacing. The way it looks not even a 3" BS rim will fit without spacers.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
fast65
Re: my 65
Post by fast65 »
Hi I've got these compromotive Fuchs going on we're I can change offsets :)
So fingers crossed I have measured it ok lol
Cheers andy
fast65
Re: my 65
Post by fast65 »
good news is ive got my car back now to go to bruce for painting :)
ive finished the other arm all i have to do if fab up a bracket for the coil overs
for a bit of extra strength i plug weled the bosses in as well
cheers andy
fast65
Re: my 65
Post by fast65 »
The java charger has reached the paint shop woo hoo it's down hill now :)
Cheers andy
fast65
Re: my 65
Post by fast65 »
bit done today started taking the car apart again
transmission out
i like this bit :)
time to take the diff out
ring gear on the quaife just need the new bearings now and find out if i need any preload i havent spotted anything yet but there maybe shims behind the bearing but not checked that yet
cheers andy
fast65
Re: my 65
Post by fast65 »
Thanks to ricola I have the diff set up details all looks v easy :D
Just got to get hold of shims now if I need any :)
Cheers andy
1938vw
Re: my 65
Post by 1938vw »
Andy, my god you've got some talent! Awesome engineering there buddy. I believe I recognise this car from the uk drag day forum?
MY JUNKYARD 1600T BUG IS NOW ON THE ROAD, THANKS STF USERS FOR ALL THE HELP!
SEE MY ENGINE BUILD
HERE
MY YOUTUBE CHANNEL HERE
fast65
Re: my 65
Post by fast65 »
Cheers I wish it was all my work I didnt do the cage, exhaust or induction jc Weldfab did that I did the rest though :)
Cheers andy
fast65
Re: my 65
Post by fast65 »
thought i would weld in the heater pockets and give it a try
20amps needed for all 4 plugs
and in one hour we have just over 90 Deg C and 50 Deg C in the oil feed line
so looks like that works :)
cheers andy
CobraJet
Re: my 65
Post by CobraJet »
Nice A-arms! Did you make the bearing carriers as well?
fast65
Re: my 65
Post by fast65 »
hi no they came from
www.sandparts.com
cheers andy
fast65
Re: my 65
Post by fast65 »
I thought I would have a go at making the breather/catch tank for the VAC pump
Baffles and 4" tube
Baffles welded in place
All welded up didn't turn out too bad I defo need to practice welding aluminium lol
Cheers andy
