Urabus...it's in the works (Subaru EJ20T build)
883
Re: Urabus...it's in the works
Post by 883 »
Just went out for a quick look, but I don't see either of these gazintas on my na 2.2. Sorry, no turbo, no helpo. :(
No plan survives contact with the enemy.
RonW
Post by RonW »
Panel,
i found this pic and it looks to go to the crank case vent. the other hose going to that same vent i routed to the breather along with the vents from each valve cover.
the other pic i am having a hard time visualizing where that is.
912R + STi 2.0 Turbo JDM v8
panel
Post by panel »
Ah......PCV valve.........I forgot I took it out.
I'll post a farther away pic of the breather tomorrow for clarification :wink:
panel
Post by panel »
RonW wrote: the other pic i am having a hard time visualizing where that is.
RonW
Post by RonW »
panel,
damn dude, youre a fawking hair gorilla aint ya ;)
i checked my motor and i dont have that port. sorry no help.
panel
Post by panel »
Sorry to ask so many stupid questions but did you do away with this metal cross over tube(yellow arrows)? That's basically what I have. Right now the intake is off for cleaning up some other tubes not used and I'd like to get rid of this metal cross over tube if all I need to do is run them to my breather boxes.
It looks like Britain just 'T''s his valve covers to his breather box also and then one goes maybe to the ground ?
RonW
Post by RonW »
panel,
I did leave it on and unmodified.
panel
Post by panel »
Not much of an update but got my turbo drain back from my Dad. I like it. Clean and simple. Now I can run an AN style off of it. Used to be a straight flared pipe coming off of it.
panel
Post by panel »
Got a couple more bits back from my miracle worker :wink:
Oil feed from block to turbo:
Coolant on block cut down and re-positioned for heater core delete(for now)
And another coolant mod on the back of the block (cut/shortened re-positioned etc)
panel
Post by panel »
Found a really good layout of my plan........
panel
Post by panel »
Got my two into one 1 3/4" merge collector back from my Day for Father's Day 8) Added the in/out water fittings from Earls.(Coast Industrial) and the oil drain is on there now too.
panel
Post by panel »
Got some smaller little things taken care of. I saw a lot of guys flipping their coolant manifolds around so the outlet faces the front of the vehicle. At first I wasn't even going to take the intake off but seeing as though it won't be on the road this summer I think this will give it a cleaner look and more of a direct shot at the radiator. It's not really flipped but re-located.
Original way(below)
Aftermarket sender location on left 1/8NPT and the OEM coolant location on the right.
This hole will be blocked off (welded in the below pic)
I also was trying to get an AN fitting from my bulkhead to go from 3/8 to 5/16 for the fuel supply line and Coast Ind. was coming up empty and online so I cut off the original hard line and will get a 3/8 steel fitting tiged on there. This actually in the end is a nicer way for the fuel layout than I was going for. Originally it was coming in right near the return line above the intake manifold and kinda looked ugly.
Complex curved steel line routing
Clean and simple routing
Ghia Nut
Post by Ghia Nut »
Really interested to see
•_•)
( •_•)>⌐■-■
(⌐■_■)
how this one pans out.
panel
Post by panel »
Got a little cleanup work done on the alternator mount. There sure was some unused castings on this thing that were ugly and needed attention.
Before
After
panel
Post by panel »
I've been collecting some more goodies:
These are some aluminum block off plates so I can relocated the 'IN' side I'll go with one big 'in' rather than two 'ins'.
K & N from GCVW this summer
VSS Vehicle Speed Sensor from Amazon
Throttle cable stop. The OEM one looked bad and I only needed the one hole
