awesome build. Makes me want to build a copy cat car! What size tires, and rim specs (17", but what with, off-set etc) you running on the 4 corners? Loving the stance, and with the low light lines will look great.
crazy tarzan wrote:awesome build. Makes me want to build a copy cat car! What size tires, and rim specs (17", but what with, off-set etc) you running on the 4 corners? Loving the stance, and with the low light lines will look great.
Great progress yesterday. The engine is running and sounds absolutely incredible! We have some trigger wheel sync issues to work out though. Again, this is due to our decision to use the stock Subaru trigger wheel.
Kevin and Redline have done an awesome job here. So if anyone else is interested in this ECU combo just know that an EZ30R plug and play option (harness, ECU, maps) will soon be available. Data logging is now available now as well.
