Page 4 of 5
Re: Starter fo 2.2 Subaru in '73 Superbeetle ?????
Posted: Fri Jul 08, 2022 9:07 pm
by panel
So no adapter needed? Is the throw the same? I see some of these adapter but they look 1/2" + thick.
Posted: Sat Jul 09, 2022 9:14 am
The "automatic" 9 tooth TDi/VR6 starter needs no adapter, just a few minutes with a rattail file to adjust the second bolt hole to line up.
The longer snout manual trans version needs the thick adapter to work on a 091 trans, and I am not sure it will work on a t1 trans.
The required strokes overlap to some extent, is something you can check given a spare trans.
Posted: Sat Jul 09, 2022 9:15 am
by panel
Great , thx again for clearing that up :wink:
Posted: Mon Jul 25, 2022 8:07 pm
by panel
Ok , got my starter and it looks like a really nice part. I saw somewhere that there was a pigtail you could buy. Anyone have a link or p/n ?
Posted: Mon Jul 25, 2022 10:16 pm
IIRC (maybe) vanagons, mk3s and mk4s had the plug, perhaps even mk5++
(Volkswagen tends to keep using designs that work for some reason)
...but you can jack the existing female 1/4" spade onto it.
(yes, its a locking spade connector... may even be waterproof. I wish you could get both sides...)
You will want to fit that hole on a spare trans if at all possible.
I think i used a chainsaw file, but I have slept since then.
Off topic, My 40x40x16 red iron framed shop is finally getting erected. :D
Posted: Tue Jul 26, 2022 9:15 am
by panel
Piledriver wrote: ↑Mon Jul 25, 2022 10:16 pm
Ah....will do. And thx for the advice re the mock up on another trans.
Posted: Sat Aug 13, 2022 7:06 pm
by panel
That starter doesn't work for me :( Hits my gas tank. Guess everyone has put these in beetles. I have pics I'll post up later of my mods. Sure is a noisy one.
Posted: Mon Aug 15, 2022 12:12 am
Spins a diesel over at -40... Have one in my square for years (now in vanagon, new one going back into square)
What hits? Starters not abnormally long or anything, smaller than most, permanent magnet and sun gears for gear reduction...
Solenoid orientation?
Posted: Mon Aug 15, 2022 11:02 am
by panel
Solenoid orientation? Yes......
Posted: Mon Aug 15, 2022 11:05 am
by panel
Some pics....
Posted: Mon Aug 15, 2022 11:07 am
by panel
Had to clock it maybe 30° ish.
Posted: Mon Aug 15, 2022 11:09 am
by panel
It's in and works great. If you hold the two side by side you'll see the mounting tabs are not in the same spot. Great for a car with no gas tank platform in the way etc. And if I was to spin it 180° the solenoid would hit the swing axle.
Posted: Mon Aug 15, 2022 11:12 am
by panel
You can see here where it should sit....
Posted: Mon Aug 15, 2022 8:17 pm
Cool, Im delighted you were able to get it working, even though it required heroics, I suspect you will find it to be worth the effort...
It spins my humble 10.5:1 CR 3.6L subaru well over 300rpm...
Posted: Fri Aug 26, 2022 6:50 pm
by panel
panel wrote: ↑Mon Jul 25, 2022 8:07 pm Ok , got my starter and it looks like a really nice part. I saw somewhere that there was a pigtail you could buy. Anyone have a link or p/n ?
I think I'm going to pursue that pigtail. So far so good but would like to know it always has that clip as security.
