72 Beetle EJ22 Build
Master slacker
Re: 72 Beetle EJ22 Build
Post by Master slacker »
Impressive build! Would you have a picture available showing where/how you made body cuts for radiator air flow in the front?
72marinablue
Post by 72marinablue »
Master slacker wrote: ↑Tue Aug 23, 2022 5:46 am Impressive build! Would you have a picture available showing where/how you made body cuts for radiator air flow in the front?
If you look back on my previous posts you will see the whole front clip while its on the bench and you can see what areas of the spare tire well i have cut out. That being said I ended up cutting more of the dent that holds the washer fluid bottle out to gain more airflow, and I ended up not using the sheet metal xbrace I fabricated at all.
