I really appreciate all the input!
I plan on making this video informative, even for those who are not building a 2270. It could be used for larger engines, or smaller engines and all through it I will add" If your engine sn't a stroker, you can skip this step" or "If you have a stroke larger than 78 you ned to check this carefully" things like that..
TIV Performance Engine Video- How much would you pay?
Guest
- samcat
Lol....Anonymous wrote:MASSIVE TYPE IV wrote:I really appreciate all the input!
I plan on making this video informative, even for those who are not building a 2270. It could be used for larger engines, or smaller engines and all through it I will add" If your engine sn't a stroker, you can skip this step" or "If you have a stroke larger than 78 you ned to check this carefully" things like that..![]()
Look at the troll!
Cya,
Sam C
ʇɐɔɯɐs
alsehendo
Nearly all the computer books I purchase that are worth a sh@#$ cost near $100 dollars. Specialty books have to be special. If it?s not detailed you won?t sell any even if it is cheep.
The volume 8 T4 video is limited to a smaller market. I think the price on it had little effect after I found out how helpful it was.
Better not hold back and don?t make it?s objective marketing for your store, but some of this added is OK.
I would put it on my Visa this second after using your last video.
Knowlege is power no pun intended
craigt-from-atl
