TIV DTM Bellcrank linkage- Stainless Steel-
MassIVe 79 Vert
Post by MassIVe 79 Vert »
He's really had it ready to go for weeks....he's just holding off cause you're bugging the piss out of him!! :shock:
JUST KIDDING :wink:
Ephry73
Post by Ephry73 »
HAHAHA, too funny :shock:
Well, I cannot wait to install that thing in the car. Thanks
E
dstar
Post by dstar »
MassIVe 79 Vert wrote:He's really had it ready to go for weeks....he's just holding off cause you're bugging the piss out of him!! :shock:
BUWAHAHAHHAHAHAHHAHAHAHAHAHAHA!
Don
davygrvy
Post by davygrvy »
Looks like the SKU# will be 13610 from the comment on the TB version
I'm watching for it too.
Ephry73
Post by Ephry73 »
Just saw it. Geez, I do not know how many times I read that add, and never really saw it.
:oops:
E
Stripped66
Post by Stripped66 »
Is that correct? The price is quite a bit more than the $180-$200 Jake had estimated in the first post. (just wondering if this includes more than the basic linkage...)
[edit: nevermind...I read the description and the price includes manifolds and air filters.]
Jake, are the manifolds included in this kit for unique for throttle bodies (e.g. lowered TB mounting height to compensate for the throttle shaft location)? The manifolds I intended to run are at the porter's, and I'm wondering if I'll have any issues with the linkage and my TWM's if I use my current manifolds?
Post by MASSIVE TYPE IV »
Yes, that arrangement is for the EFI set up only...
The carb set up will be in the neighborhood of 175.00 and will no longer require extra hassles of welding on the generator stand- it all bolts on!
Here is an idea of what it looks like with carbs, in stealth mode.
davygrvy
Post by davygrvy »
eww.. that's clean.. I'm mailing my check now..
Stripped66
So, if I already have manifolds, I should be able to use the carb set-up on my TB's without requiring the new manifolds supplied in your EFI-specific kit?
[edit: I think I found the answer in the CSP manifold thread...man, I've gotta start reading more before I post :? ]
Yes, All you would need are the T/B rod ends instead of the carbed ones... I will have a kit for EFI without the manifolds and etc just for guys like you.
The linkage is the same, it is vastly adjustable for either arrangement.
Stripped66
Both will be on the site tonight....
I welded the mounts last night and completed the templates today to locate the drill marks on the generator stand.
The price went up a few dollrs with the added complexity of thr mount tabs, BUT NO WELDING IS NECESSARY for the use3r- it all bolts on after you drill and tap two 8mm X 1.25 holes (tap included).
The system will work with ANY DTM, Joe's or mine. :shock:
More later tonight.
kansas buggy
Post by kansas buggy »
Marke one sold to me.
Will look for the inclusion on the Type 4 Store site. What section will you be putting it in?
Roy
It'll be in 3 different sections.. I'll post links.
I might not get it done tonight, damn Flu hit me or something earlier today and I feel like crap.
I'll do my best, people are screaming for these!
Ephry73
Post by Ephry73 »
Jake, God bless you man! and God bless your obsessive compulsive behavious too! I mean it in a good way.
So, is it all god to place an order for the linkage?
Ephry
Locked
