Awesome on the new job....
Steve Arndt baja build project
- bajaherbie
Re: Steve Arndt baja build project
- CentralWAbaja
Nicely done man. Been passing through your town a lot lately. One of these days I need to give you a shout and and grab a bite or something.
Steve Arndt
My van broke so I've been daily driving Bugly to work this week. I took her out last weekend to play in the foothills above Boise a little bit. Hit the clouds at 5k feet. It was first gear speed visibility was so reduced. On the weekends there are a lot of crazy jeep drivers up there so going slow is prudent.
I've developed an oil leek near my sending units. Hopefully its just the gauge or pressure sensor and no a cracked case where the fitting goes in. I'll clean it up and fix that.
I haven't put a wrench to the bug since November 2016 just been driving it. I should probably change the oil soon close to two years on it.
Steve
My Baja Build
My Baja Build
Steve Arndt
Been averaging 25 miles per gallon doing in town driving mostly. My left knee hates the clutch. There are 4.40 r/p sets available aftermarket for the bus automatic. I'm pretty tempted to put an auto in it.
Steve
My Baja Build
My Baja Build
- Chip Birks
What clutch is in it Steve? Something heavy? Or just a bad knee?
Steve Arndt
stage 2 2100, copper head. late pedal assembly. 100mm cross shaft arm. bad knee.
Steve
My Baja Build
My Baja Build
