Lord Bajamungus build
- kyle_pc_75
Re: Lord Bajamungus build
I didn't get nearly as much done as I wanted, but it's progress. The body is mounted and I like the idea of just losing the louvers, I just want to retain the option of rear glass. I am thinking of mounting the oil cooler in the back window instead of on the roof like it is now.
As to your oil filter mounting, on the side of the bumper cage works nicely.
- Leatherneck
You shouldn't have a problem keeping the window as long as you leave some meat between your cutout and the window channel and keep the heat moving around.
- dustymojave
Leather, one reason not to take those louvers out is how much it weakens the body under the rear window. You can take them out for space, but I suggest bracing the back of the body to the roll cage if you do.
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
^^^^ The rolled edges of the vents are structural for both the vents and the area below the windows.^^^^
They work kind of like beading or the raised areas on the pan halves.
Added the "Y" to "the" at the start of the above sentence.
- Leatherneck
Dusty wouldn't suggest taking them out without building something to take it's place, earlier I suggested adding some sheet stock making the room for the cleaner.Leatherneck wrote: ↑Sat Feb 18, 2017 6:06 pm I have seen a lot of filters mounted on the firewall, since the louvers are not being used why not take them out and mold in some sheet stock to make room for the Air Cleaner. Nice list you have.
- kyle_pc_75
Gotcha, thanks guys. Went skiing today and then met with some media people who're going to help with BOR, but I might get some work done tomorrow. The powder is calling, though...best winter in ten years.
- kyle_pc_75
Well, I've worked on the car the last three days. Photobucket is down, and the pics aren't exciting, I just know you guys like proof. Anyway, I got the body back in position and bolted down, re-fitted the cage, and reinstalled the CV's and axles.
Little steps are making me feel good!
Biggest stuff to make it driveable is electrical, fuel and oil plumbing, bleeding the brakes.
Good for you Kyle, I am sure you will be very happy to drive her. You have a lot less to do than I do LOL.
Ed
Ed
- Leatherneck
Good to hear the progress though seeing is believing
Glad you are making progress. Get busy Ed.
- dustymojave
I've been having trouble with Photobucket too. Sometimes they're the cool deal, sometimes they're a real PITA.
Richard
Retired Fabricator
Retired Fabricator
- kyle_pc_75
Still no photobucket, I'm going to look at another option. It works fine on my phone and if you're on Facebook you can see them there.
Today:
Engine cage done, rear shocks installed, driver seat mount mocked up, oil filter mounted, VHF reinstalled and a bunch of little odds and ends I found while crawling around the car.
Today:
- CentralWAbaja
Good to see you motivated and rocking on the car Kyle!
- Leatherneck
I resize and post here, for the most part they stay, with Facebook you move or delete and they are gone here too. Stay Motivated.
- kyle_pc_75
Photophucket is over, none of the links work now, and I tried Imgur, but it doesn't work either lol. Anyway, today I got another bunch of odds and ends done. Seat mount (driver side only lol) is close, battery box and ground strap are in, redid the lower front shock mount spacers so they're not hitting the upper arms, installed the rear skid plate, installed the steering column (the steering wheel is not in the 12 o'clock position, just an annoyance), I guess that's it. It feels like I did so much more, dangit.
