Chip's Turbo EFI Build
buguy
Re: Chip's Turbo EFI Build
Post by buguy »
I didn't know Shag was still on the scene.
Post by Chip Birks »
buguy wrote: ↑Fri Apr 17, 2020 12:06 pm I didn't know Shag was still on the scene.
Oh yes, just not here.
The compound was fun, I won't lie. It got lots of attention too, but it was a lot of work, and ultimately it felt like I was trying to make two inefficient turbos try to act like one nice one. I figured why not just try buying a nice one. After lots of consulting with Mario(thank again for your counsel), I settled on one that hopefully will do the trick. It should have headroom for days, and a modern design that hopefully will come to life quickly and be happy with plenty of rpm on the top end. I'm trying to get the car together for a big event in Las Vegas in October. Hopefully I can make it happen. Wally the turbo came in a blue and brown box. Hopefully it does a good job.
panel
Post by panel »
I see a few on IG from him.
Wally
Post by Wally »
Chip Birks wrote: ↑Fri Apr 17, 2020 12:44 pm Wally the turbo came in a blue and brown box. Hopefully it does a good job.
Can't go wrong with that :D
Compound is a lot of work indeed and 95% of the time the proper single will do all you need and better.
For some set-ups I still think its awesome and gives a range that otherwise really is impossible to get.
I still think what I had for the 1200 compound Challenge engine, was great, but I made an tiny mistake on the crank, which made me leave the project alltogether as well. Maybe one day..
Schweg
Post by Schweg »
You guys really make it hard to want to even try a compound set up.
It’s a fair amount of planing and work to set up and both you and Wally basically are in the it’s not worth it camp.
Clonebug
Post by Clonebug »
It's all about picking the right turbo......and knowing what you want out of your setup.
I've spent a fair amount of thought on a compound setup and I haven't come up with a reasonable layout that would be worth doing...yet.
As much as I want to try the Holset turbo either singularly or compound...it just hasn't jumped out and said ......do it this way.
As I said......pick a hp target you want and then buy or find a turbo that will support that target.
As much fun as 400 hp out of a small engine would be... there is going to be some sacrifice to get there.
Chip has a good combo since he has the cubic inches to get there fairly easily........I'll continue my rambling on my own thread........
Alrighty, just a little comparison for you guys. Here is my the new turbo, compared to a tdo4-13t I have.
Here is my old t3/t04e setup. Compared to the new one.
buguy
Post by buguy »
I think your going to need a new air filter!
Gonna need new everything!
buguy
Post by buguy »
It's just green paper!
Schweg
Post by Schweg »
Chip Birks wrote: ↑Sat Apr 18, 2020 8:20 am Gonna need new everything!
Well, better start selling the old!
Schweg wrote: ↑Sat Apr 18, 2020 10:05 am
Already sold the header and first turbo I purchased for the car. Another VW of mine may inherit a few boost bits from it's big brother, but not much, probably the little blow off, the muffler and one of the wastegates. The intercooler is probably headed to a friend of mine, not sure what will happen with the plenums and other tubing...
Wally
Post by Wally »
You got it with a single scroll turbine housing? Which one exactly is it?
