Building the Ultimate Killer Bee!
- MNAirHead
Oh yea... I drive the 3 wheeler in a -40 sleet storm with nuttin but a thong.... you autta see the pix.scott the viking wrote:OH YEAH....well I ride a motorcycle with nothing more than a tank top, a pair of camo shorts and flip flops....AAAAND when I get where I am going...I stretch my hand out on the gas tank and smack the end of my finger with a tack hammer. I have recently been building a shield to try and prevent any of the engine heat from providing me with comfort.
T.
- scott the viking
PASSMNAirHead wrote:Oh yea... I drive the 3 wheeler in a -40 sleet storm with nuttin but a thong.... you autta see the pix.scott the viking wrote:OH YEAH....well I ride a motorcycle with nothing more than a tank top, a pair of camo shorts and flip flops....AAAAND when I get where I am going...I stretch my hand out on the gas tank and smack the end of my finger with a tack hammer. I have recently been building a shield to try and prevent any of the engine heat from providing me with comfort.
T.
- thrown_hammer
Much to the shigrin(SP?) of most here I have decided to go the Redux Bus tranny route. Details are in the works. This will give me over 13" of ground clearance without the dreaded swing axle camber dilemma. Since I have no money, limited fab skills, and my Bug is a crawler not a flyer this is the best fit for me.
Technically it IS a bus trans...
- david58
Technically I should know better to say something since Baja5 backed up Scott the Viking about a simple spark issue, but you still have a swing axle. With Bugzilla adaptors you lose clearence untillyou notch the spring plates and jack the torsion springs up. You still have a swing axle.thrown_hammer wrote:Much to the shigrin(SP?) of most here I have decided to go the Redux Bus tranny route. Details are in the works. This will give me over 13" of ground clearance without the dreaded swing axle camber dilemma. Since I have no money, limited fab skills, and my Bug is a crawler not a flyer this is the best fit for me.
- david58
[/url]
I wish that was so with Bugzilla adapters. Their adapters move the axle tube about 3 inches or so higher than the center of the spring plate. The axle tube on a swing axle goes thru the center of the spring plate. I thought the same thing until I installed their adapters. The pic posted is not their adapter, but it does show the relationship to where the axle tube is with using their adapters.MNAirHead wrote:You do not loose clearance with a redux.. depending on your hop threashold you gain up to 3" without notching.
T.
- scott the viking
Backed up? Is that what that's called? Seemed a little more like me being called a petty jerk than back-up.David58bug wrote:Technically I should know better to say something since Baja5 backed up Scott the Viking about a simple spark issuethrown_hammer wrote:Much to the shigrin(SP?) of most here I have decided to go the Redux Bus tranny route. Details are in the works. This will give me over 13" of ground clearance without the dreaded swing axle camber dilemma. Since I have no money, limited fab skills, and my Bug is a crawler not a flyer this is the best fit for me.
- thrown_hammer
- thrown_hammer
- david58
I wish I had it was about a year ago when I put them on. I called Bugzilla and asked them what was up. I was told I had to reindex the torsion bars and notch the spring plates. The Johnson adapters are the way to go, but finding a set is another story. They require dis-mantling the gear reduxes and pressing the housings off the axle tube in order to install them. Special tools are needed to press out the bearings, so be careful.
- thrown_hammer
