Schematics, diagrams and shop drawings.
panel
Post by panel »
Anyone know how to change the older 4 wire flasher on a '65 bus over to the newer 3 prong flasher (12v) :?:
MNAirHead
Post by MNAirHead »
MNAirHead
Post by MNAirHead »
MNAirHead
Post by MNAirHead »
MNAirHead
Post by MNAirHead »
Starting Issues
ricroz wrote:Start by cleaning the contact from the ignition at the starter, This often gets grimey or corroded from the harsh environment it lives in:
You can do the jumper wire test to isolate the problem to the wiring or the starter itself. Make sure the tranny is in neutral and parking brake set!
Some owners choose to add an intermediate relay to help with low current issues:
Dale M.
Re: Schematics, diagrams and shop drawings.
Post by Dale M. »
A lot of my sketches/graphics have appeared over time, all over the internet....
Now they are all online in one place.... 180+ of them...
http://www.mydune-buggy.com/gallery/index.php?cat=10001
They are posted under the user, "Admin"...
Dale M. (DLM)
1968 Beetle speedometer bulb identification
Dale M. wrote:Look here.... IF its a internal ALT (AL82X) make selection.... Probably 75-79 Type 1
http://www.aircooled.net/new-bin/viewpr ... 04&cartid=
Also....
http://www2.cip1.com/ProductDetails.asp ... 087-003-US
Only you will know for sure what alternator you have and what may fit.......
Look all over I-net........ May be other sources or better pricing....
Also you will have to pull alternator, remove fan and remove rear bearing plate of alt to access VR inside alt case... OR if you are lucky you will have access to alt reg from top like in this graphic...
Dale
