Six-seven Turbo Projekt
Hotrodvw
Re: Six-seven Turbo Projekt
Post by Hotrodvw »
I don't think the deck lid is going to work out, at least not like this.
Vee Dub Nut
Post by Vee Dub Nut »
heh.. you could route your exhaust out of your weber window :lol:
think standard stand offs will do the trick, or is it going to take some custom touches?
Hotrodvw
Post by Hotrodvw »
I don't think stand offs will be enough.......maybe 4"-6" worth of extension will get it on there. Where there's a will, there's a way! If that doesn't work, There may be some 'lightening' going on. :lol:
bigwigracecars
Post by bigwigracecars »
Can you stuff the carb farther back into the right corner, and use a 45-degree elbow to between the carb manifold and the turbo?
miniman82
Post by miniman82 »
An SU carb would be a much better choice for packaging reasons...
Hotrodvw
Post by Hotrodvw »
I'm not changing carbs Nick. 8)
I thought about trying to 45 it in there, but I'm not convinced it would be enough. I'll make it work.
Hotrodvw
Post by Hotrodvw »
Vee Dub Nut wrote:heh.. you could route your exhaust out of your weber window :lol:
Don't tempt me! :lol:
miniman82
Post by miniman82 »
It's not too late for injection, and I know you could make it look purdy with all those tubes and hoses you got access to. :lol:
Hotrodvw
Post by Hotrodvw »
That's next winter's project.
WickedWagens
Post by WickedWagens »
I know you just put it there, but you could gain a little moving the fuel pressure reg.
Hotrodvw
Post by Hotrodvw »
How so??? THe reg is mounted to the back of the shroud. I don't see anythign to gain there.
Stripped66
Post by Stripped66 »
Maybe he was thinking relocating the fuel-pressure gauge (though I doubt it's standing tall enough to interfere with the shroud any more than the carb is). However, I also vote for angling the carb back towards the front corner of the engine bay. Very clean looking build, BTW.
WickedWagens
Hotrodvw wrote: Image
Yes, Sorry I meant fuel pressure gauge. It looks like it is sticking out the farthest where the decklid is curving back towards the body.
Hotrodvw
Post by Hotrodvw »
If you look at the 90* fitting it's threaded in to, it's going to hit that if the gauge isn't there. So really the lid will only go down another 1" or so. I may look into the 45* thing.... we'll see.
miniman82
Post by miniman82 »
Just do like the Fiat 500/600 racers do:
