panel wrote:Not to hijack but is the Volvo highly modded?
You could say that, it has a 6.0 chevy motor with a 70mm Chinese turbo on it. Runs on megasquirt and motor is bone stock less valve springs and pushrods. Runs 10.70's on 10 psi and has been very reliable. I want to turn up the power but doing some suspension work on it now and need to add safety equipment before I can go back to the track. I built this car after selling my oval, not as cool as a vw by any means but it's been fun to try something new, any it's way cheaper.
Buggin_74 wrote:Hi Jeff,
Just wondering what you did for a radiator for the charge cooler?
I've been toying with the idea for mine for a while, just having trouble working out where to put a charge cooler rad as I already have A/C condenser up in front of my rad.
Cheers, Joel
I just used a 96 pass oil cooler, with a bosch intercooler pump. This setup didn't have an extra water tank, which I think would have really helped but didn't want to put anything inside the car. The wrx turbo on the 2.2 was almost constantly in boost so the water temp never really gets a chance to recover during cruising or light load.
