As it was, with the car being LHD, the shift rods for the sequential shifter which exit the box on the left hand side would have had to go through the centre of the seat, as my seat is mounted more centraly than normal to give me sufficient leg room.
We've overcome this by making a custom billet shift fork mounting system that exits on the other side of the nose cone so the shift rods will come down the right hand side of centre and clear the seat.
Paul also advised that due to the rear suspension design, whilst we can use the Corvette stub axles, we can't use the Corvette drive shafts as they won't work with the output of the spool and our need for a slip joint. As strange as it may seem, the best axles to use in our application are from Ferrari which according to Paul are rated at over 800 bhp as a pair which should be more than up to the job.
Rob has also been busy and will be along with an update soon.
