The Blunderbus, bus #2
Re: So it begins, bus #2
Fuser, a silly question: are there any flair kits for Jeeps and the like that might help you on the rear radiuses.
- fusername
heh probably, but my wheel is actually in the well still. oh so very barely, but it is. I am gonna hit the edge w/ a file and paint and call it good. may get some trim beading to slip over it once I am happy w/ the curve. originally I was gonna do fender flares, but that seems unecassary now, which is great cause I don't need to worry about the slider hitting htem.
- bajaherbie
no flares needed... it's a shaggin' wagon and/or stabbin' cabin.
- fusername
Stabbin cabin, I like it
- fusername
So I just spent two hours out in the driveway sorting out a few simple things, and I am officially not solid. Looks like I need to bust out a couple hundred more $$.
Bought some really nice heater boxes. Wrong style
My known good fuel pump is, well, dead
Both the babtteries I had thought would be good enough for a season or three are dead
Broken lower shock bolt is NOT coming out of the dang arm
sheet metal work is haaaarrrrrrddd :whiney emoticon:
My electrical issues are a bit less cosmetic than I initially thought...
- fusername
ok, put out some feelers, found most of the junk I need. Rolling around on the ground tonight, doing all the hard lines. Fuel tank is IN!!!!! that has been nagging me almost since I got the car, since the tank it came w/ was not FI, and the filler setup was all manner of different, and I got away w/o moding the tank. In hindsight, I wasted days on this cause I found a crazy simple solution, but it took dumb luck to get me here, here's to hoping it continues tonight!
- fusername
had about an hour free, fought some really stuck sheet metal screws (gonna order something fancy from Mcmaster tonight, either SS or square/torx drive, never again phillips, never again) and cleaned up on the head. Utah dirt freaking everywhere, mixed w/ oil. honestly feel kinda sad killing that evidence of fun times past.
Drilled out a sheet metal screw hole to M10, since some idiot must have swapped sides w/ the heads, and there is no wehre for the head temp sensor to mount... Of course I bought a full set of metric taps, and its the one size I don't have. M10x1.00, gonna verify in the daylight against an actual sensor, but that could be right.
removed wrong style sheetmetal for my new ehxuast, yay!
Still have no idea if I have the right sheet metal to go back in though....
cut a notch in the head for a cyliner head temp sender, no more modifying the sender and always wondering if it seated proper or not.
Threw some primer at the engine bay to keep it reasonable till summer and free time???? rolls around again.
runied some brake line trying to replace the lines last night. first 3 flares go perfect, next 5 are all cut offs!! I am doing something wrong, not sure what. Hopeing a better job of de-burring is all that is needed. Going to do the rear brake lines that go over the transmission, then focus solely on putting the engine/trans back in. Hesitant to put that in before the exhaust and tins are all in, but I think it makes sense. I'll just leave it loose....
Remember, there is a difference between Phillips and cross-head. In order to use a Phillips head screwdriver on a cross-head screw you have to dress the point down a bit. The Phillips is deeper into the the head/body hence the head is not quite as strong where it joins the shank.
- fusername
oof, yes, cross head. dag nab it. that's my problem! I used to have a GREAT screw driver, it vanished along w/ my absurdly long phillips and flat heads and backup set of 410s. someone has em....
any input on what hardware I should replace stock w? I remember mcmaster having a sad selection, I am brwosing around right now.
People usually confused cross-head and Phillips head so they usually end up boogering up the head of the fasteners. The distance of the depth of dressing of the screw driver isn't that much. I have a couple of 'drivers I got a bit too ambitious with and they are not worth anything other than being used as levers/drifts or removing nose hair.
I'm not sure but I think there are actually one or two additional similar looking fastener heads to the two we are talking about; it’s been too long now since I was into the standards.
- fusername
cross head is a head w/ two flat head slots in it, not quite intended for a cross looking driver. There is phillips head, which is DESIGNED to cam out, and there is a Frearson head, wihch is like a phillips but it is pointier, and designed such that even the wrong size Frearson driver will fit well into the other size screws.
MORE THAN YOU EVER WANTED TO KNOW
http://www.instructables.com/id/When-a- ... -Phillips/
BAJA-IT
And then there is the "Pozidriv" screws. A phillips driver will round these out too.
BRAT Motorsports #936
The cross-head screw you are talking about, the one designed for a close tolerance/access slot/blade type of screwdrivers is usually used in electrical; you even see it in some older points style distributors. There is another screw that the fed spec (NAS, AN, AND, Mil-, etc.) nomenclature for it is “cross-head” vs. the other style which is referred to as a “Phillips” or “Phillips Head”; it is deep sunk like a Phillips but just not as deep and has a more flat bottom compared to the Phillips pointed style. There are also really cheap... no chinchy (Embarrassingly stingy) versions that are easy to twist the head off of (probably cast from zink or peanut butter); been there done it.fusername wrote:cross head is a head w/ two flat head slots in it, not quite intended for a cross looking driver. There is phillips head, which is DESIGNED to cam out, and there is a Frearson head, wihch is like a phillips but it is pointier, and designed such that even the wrong size Frearson driver will fit well into the other size screws.
You see some bits/screwdrivers that have short depth heads on them which, I think, are supposed to work on both styles of heads. Like I said, trying to use a Phillips head screwdriver on a cross-head screw will bugger the recess in no time because the blades don’t get in deep enough to get a good full “purchase”.
Interesting page you posted.
- Big Dave
I've always known them as a reed and prince screwdriver.
I don't always show my signature. But when I do, it's in this area.
A new name for me, never heard that one before.Big Dave wrote:I've always known them as a reed and prince screwdriver.
