Huh? The piston? I thought I said on the small-end of the rod...dstar wrote:You can't run an offset bushing in the piston......
Don
[and I edited that post because I mispelled "bushing" as "pushing"]
Quote: Chevy journals are as small as you'd want to go?Stripped66 wrote:That's just it...I know the 46mm Rabbit journals are junk. The 48mm journals will give me two rod and bearing options, both of which have excellent bearings.
I'm just looking for feedback on how this may affect the crank. The 46mm Rabbit journals have a reputation based on experience...they weaken the crank; the 2L journals have a reputation based on the uber-poor quality bearings (and nothing else from what I've read).
See my question? There's a bit of dogma floating around that the Chevy journals are as small as you'd want to go. So, that means that the 50mm 2L journals are too small, right? Nobody can answer that because all 1st hand reports are that the 2L rod bearings are shite...crappy rod bearings cannot speak for the strength of a crank with smaller journals.
So...it looks like I am at a cross-road here. Either take a risk and do something that nobody has done (or that somebody has done but won't divulge any info on it), or weld the journals up to Chevy diameter, or sell it.
That was the dogma that I was attempting to challenge...moreso, we know Rabbit journals significantly weaken a crank (especially a Type 1), but the 2L rod journal reputation is derived solely from the poor bearings and not crank strength.V6914 wrote:Quote: Chevy journals are as small as you'd want to go?
The rabbit rod issue, I don't think it's all that much of an issue on type lV's, type 1's I don't know, I never asked,cause I don't play with those anymore , but the type lV crank is a little beefier than a type 1, and isn't all a 2.0 ltr crank, just a factory offset ground 1.8 crank?Stripped66 wrote:That was the dogma that I was attempting to challenge...moreso, we know Rabbit journals significantly weaken a crank (especially a Type 1), but the 2L rod journal reputation is derived solely from the poor bearings and not crank strength.V6914 wrote:Quote: Chevy journals are as small as you'd want to go?
Finally, I encourage anybody else to research this. I've already provided the specs and necessary mods to run either the 3SGTE or 420A rods, either with their stock bearings (e.g. journal mods) or modified for larger Dodge 2.2L bearings. The Dodge 2.2L rods and SRT-4 rods bolt right in (sans rod bolt flipping for clearance, if necessary); the SRT-4 were uber-attractive because they have 22mm small-ends, and I have pistons with 22mm wrist-pins...but, alas, the length is prohibitive. If anybody else could locate other suitable rod/bearing options, please post up! This info can only help the body of knowledge regarding the Type 4 engine.
I asked my wife if I could take out a loan to buy Russ' engine...she said no, too.V6914 wrote:So, I guess I am gonna get those Pauter 2.0 ltr jrl rods, 5.4 length, 24mm pin, so that means I'll have to have them rebushed, for a 23.5 mm pin thats a chevy .927" pin, and have the big end resized and retanged for the dodge bearibgs.
How, many times did she say no?Stripped66 wrote:I asked my wife if I could take out a loan to buy Russ' engine...she said no, too.V6914 wrote:So, I guess I am gonna get those Pauter 2.0 ltr jrl rods, 5.4 length, 24mm pin, so that means I'll have to have them rebushed, for a 23.5 mm pin thats a chevy .927" pin, and have the big end resized and retanged for the dodge bearibgs.
BTW, why not have Pauter just make the rods with the big-end already sized for the Dodge bearing and the small end bushed for the Chevy pin? I can't imagine the additional cost for custom over their pre-spec'd rods (it's not like they've got 5.4" 2L rods sitting on a shelf) would cost more than sending them out to another machine shop for the finish work.
V6914 wrote: They, will be a drop in, but I did want at the least a 5.5 rod, pistons I'am using are Ross 4.125" bore (104.8mm), .930 compression heigth, around 410g, .927 pins, I have 4 at 130g Casidium coated, another 4 at 80g Titanium, Casidium coated, crank DPR 82mm 2.0 jrl, that will make a 2828.
Santas Brother wrote:.930 compression height is pretty short for a chevy.
That is the stock bore in a 400,I'm guessing those pistons
are for 6" rods in a 400 sbc ? Do you have a part number ?
What are you running for barrels and heads ?
And how much room are you going to have for a cam ?
Thanks.
Ian
,V6914 wrote: They, will be a drop in, but I did want at the least a 5.5 rod, pistons I'am using are Ross 4.125" bore (104.8mm), .930 compression heigth, around 410g, .927 pins, I have 4 at 130g Casidium coated, another 4 at 80g Titanium, Casidium coated, crank DPR 82mm 2.0 jrl, that will make a 2828.
Hi EddieEddie Brown wrote:Richard, it was great meeting you over at European. I hope to pick your brain more as get into working on the 914.
Take care,
Eddie.
Well, I had the chance, and didn't take it, went back, but the Pauter rods were gone, somebody jumped on them.Back to lookingV6914 wrote:The rabbit rod issue, I don't think it's all that much of an issue on type lV's, type 1's I don't know, I never asked,cause I don't play with those anymore , but the type lV crank is a little beefier than a type 1, and isn't all a 2.0 ltr crank, just a factory offset ground 1.8 crank?Stripped66 wrote:That was the dogma that I was attempting to challenge...moreso, we know Rabbit journals significantly weaken a crank (especially a Type 1), but the 2L rod journal reputation is derived solely from the poor bearings and not crank strength.V6914 wrote:Quote: Chevy journals are as small as you'd want to go?
I, just got back from dinner, and I asked my wife whats she gonna get me for xmas, she said nothing, I said you could buy me some new rods for my motor for xmas, she said NO, then she asked how much they were, I told her, she said NO REAL LOUD this time, then she said, she'll pay for half.![]()
I, don't have the Toyota rods close by, but I remember them having a smaller out side dia. , but there's not enough room to open up for Chevy bearings, I probally pushed the limit, when I opened them up to fit the Dodge bearing, 2.086", where the Chevy is 2.125".Santas Brother wrote:How does the outside to outside dimension
(across the big end) compare between the
Toyota and Chevy rods ?
Any chance the big end of Toyota rod
could be opened up to accept the Chevy bearings ?
Thanks.
