Great time at BK Dyno day! interesting data within....
huw'sspeedster
Post by huw'sspeedster »
That sounds like a great solution,btw there is more room behind the valance of the speedster!No inner wing in the way!I'll wait with expectation on your results!!
Huw
dstar5000
Post by dstar5000 »
kansas buggy wrote:-------
I would be intrested in the sidewinder system for a Dune Buggy application.-----
Tri-Mil and Fat Performance are all over the offroad T4 crowd.
I doubt anyone can come close to their prices. As for performance,
no one has did a side-by-side, due to market over-saturation by
the two aforementioned companies..
Don
kansas buggy
Post by kansas buggy »
I need to make a point about Buggies. Not all are for off road. Mine is realy a slot racer instead of somthing to run in the off rowd. It currently has a Tri-Mill exhaust for its 2316 RAT motor.
My dissatisfaction with that system is it leaks. The leaks leave uggley tracks and in some cases cause popping in the exhaust. I have spent considerable time in stopping it from leaking just to have it leak later in the same place or leak at some other place.
I see the A-1 as a system that may not leak.
Jake as to the development. I am open for discussion. It may be that very littel is needed. It may just require small modifycation to the cage to accomidate the sidewinder. Who knows with out looking into the issue.
The current A-1 system would look a little funny on a buggy with the exhaust extending behind the cage and than raping arount it.
Post by MASSIVE TYPE IV »
I will be posting pics of our latest off road system on a Super Hero I just finished up in a few days. It is made for a Buggy. This one is already deveoped and known to work on a 2493cc engine.
kansas buggy
Which muffler?
I am open to looking at it and I will be wating to see thoes photo's.
Roy
dstar5000
Post by dstar5000 »
When I posted *buggies*, I was meaning a vehicle with an open
rear end, which has more space available than bug.
I DO understand what you arer saying, as I am building a sand rail,
that will NEVER see any sand..........
:lol:
Don
tallqball
Post by tallqball »
I'm also in the market for an exhaust on my Bradley. I wonder if the collector could be rotated up on the A-1 system, and then bend the pipe back down for the muffler.
The exhaust would ideally be close to stock in clearance. I have a few grind marks on the bottom of my "quiet power" system that I ran for so many years. Don't want to go lower!!! :shock:
Wally
Post by Wally »
Found the link for most all of the data of the dyno-day at the speed-forum:
http://www.sevwa.com/dyno_day_participants.htm
Very cool events!
But what was wrong with Zen's engine that day? :?
Walter
Zen needs a tune up...
And his exhaust has been altered since it was dynoed at my shop....
He needs an A-1 in a bad way.
Also those big brakes and tires are for sure hurting his chassis dyno numbers.
Locked
