Turbo Gallery
Re: Turbo Gallery
This is my 1835 turbo blow through 40 mm dell I boated 25 psi daily driven.
And also my vr6 69 turbo bug the vr6 was out of a 97 Passat Glx
Re: Turbo Gallery
Work in progress.
86X94
CE 48X38
13"X10" Intercooler
65mm TB
HX40 Turbo
Fueltech FT350 ECU
86X94
CE 48X38
13"X10" Intercooler
65mm TB
HX40 Turbo
Fueltech FT350 ECU
- Udo Airbus
Re: Turbo Gallery
This is my home made 1600DP supercharged engine.
Again N/A now. because I'm building a 1971CC T4 EFI turbo engine..
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, 1915cc
Re: Turbo Gallery
my budget build... whole project, car included, im in less than $3K.
89 bhp and counting
Re: Turbo Gallery
Mud slinger do you have a build thread or what specs do you have on the 1835? What cr? And carb jetting. I have same engine
Re: Turbo Gallery
New to turbo'd VW, moving up from stock 1200, to mild 1776, to now a 2176 Turbo Buggy.
Short list of engine/performance stuff:
AS41 case 94X78.5 (2176cc)
compression ratio at 8.3:1
SuperFlo heads (44 mm intake, 37.8 mm exhaust, measured at 52cc)
Engle FK8 cam
Bugpack 1.4:1 rockers w/dual Hi-Rev Springs & chromoly retainers
Ignition - MSD 6AL Controller, MSD-8485 Pro Billet Distributor, MSD wires
1 5/8” exhaust w/SPD 4-1 collector w/turbo star (custom equal length
header)
Custom Garrett T3/T4 Turbo by G-Pop Shop regulated at 8# boost
Weber Sidedraft – DCOE 45 (Main Jet = 225, Idle Jet = 85, Air Correction
Jet = 200, Emulsion Tube = F2, Venturi = 36mm)
Other - Jaycee Performance Billet Blue Oil Filter System with Pressure
By-Pass
Other - Holley Red Electric Pump w/Turbo/Boost Sensitive Regulator
Other - Kennedy Stage-2 w/Center Force dual friction 8-puck disc
Other - Custom Performance Street '67 transaxle by Geno Boyd (3.88 R&P)
Engle FK8 cam
header)
By-Pass
Re: Turbo Gallery
Well here is a build i just finished
1600 dp all stock long block
cb intakes
hyundai tb
custom center intake
volvo injectors
td03-o8g turbo
bosch bov
ms1 v3
innovate lc-2
14 psi
http://i1348.photobucket.com/albums/p73 ... usyzwz.jpg
cb intakes
hyundai tb
volvo injectors
td03-o8g turbo
bosch bov
ms1 v3
innovate lc-2
14 psi
Re: Turbo Gallery
Back to the twins again
Re: Turbo Gallery
busmotor
- panel
Re: Turbo Gallery
^ great looking motor ya got there !
Re: Turbo Gallery
The turbo is not hooked up yet in that photo is it, or do I need more coffee?
Looking good!
1973 Karmann Ghia
Turbocharged, Fuel Injected, and Fast!
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
Re: Turbo Gallery
that shroud is something else!
- panel
Re: Turbo Gallery
Re: Turbo Gallery
Added intercooler. Deck lid is offset top and bottom
