Page 6 of 24
Re: my t4 in a notch build
Posted: Mon May 30, 2011 3:30 pm
by Munchhausen
supaninja wrote:Pile- do those vanagon mounts bolt to a regular bus hanger bar. I like the idea of preventing motor rock/torquing.
I like it too: just bought two of that vanagon rubber suckers in the bay
supaninja wrote:
Munch- Post up some pics from Wolfsburg! I'm super jealous!
Will do
Posted: Mon May 30, 2011 4:16 pm
I welded on some 2" angle steel "wings" to the factory Bus steel block side mount bits, using the factory rubber mounts as a positioning device. They are close enough to "right" on the bar side for s simple hole, although IIRC I welded in some 1/2" tubing for the bolt holes.
The Vanagon mounts directed me where to cut and weld/angles etc.
I'm using a Golf/Rabbit oil filter as I was concerned about the slightly reduced clearance, but it actually has about the same as factory with the stock filter, so I may eventually switch back.
It seems to work great other than the factory trans nosecone mount, it seems to be allowing significant up/down movement.
A "new" nosecone mount may happen this week, made from a SBC engine mount. (TBD)
If I had to do it again, I'd probably weld in some CrMo tubing for faux frame horns and a kafer style brace tying everything to the rear suspension, and go with a mid mount, skipping the rear bar entirely. (sort of make a rear subframe all attached to the T3 torsion)
It may happen yet...
Ninja--- That's probably the best plan for you when you add the Bus trans.
You may want to go with the Berg nosecone and T1 shift forks etc. (Tom Notch's setup)
I'm still keeping my eyes peeled for a 411 automatic. (IIRC higher gearing and IMHO stronger than an 091)
Posted: Mon May 30, 2011 4:28 pm
by supaninja
Here you go pile, I have been entertaining welding this to a IRS subframe (which I may be finally getting next weekend)
http://www.thesamba.com/vw/classifieds/ ... ?id=892969
Posted: Mon May 30, 2011 4:30 pm
Oh hell yes... My only concern going that route is the turbo header I have planned, based on a QSC Kerry Hunter knockoff.
It will clear the std late setup, but the frame horns may cause issues.
Hmm... Might be able to use that 944 torsion after all.
Posted: Tue May 31, 2011 1:13 am
by Munchhausen
Piledriver wrote:They are close enough to "right" on the bar side for s simple hole
Thanks. Would have been my next question
Want to see pics
Want to stay with stock for the moment. Dreaming of UN1-box. But have to make shure not to lose my historical registration. Loosing it would lead to painfull taxes for the T3. Maybe the 914-box is the only historical correct conversion.
Whats new in mind is a sportomatic from early 911. But seems to be the most expensive way. Boxes are cheap, spareparts are unaffordable.
My idea with that is the porsche style:
Then the nosecone can proper handle motor rock/torquing the first time
IMHO the rear bar is a perfect place for mounting the haevy T4 engine. Woudnt skip it.
Munch
Posted: Tue May 31, 2011 5:43 am
Hmmm.. That Porsche 911 front mount gives me some Bad Ideas.
I have a spare set of 914 trans mounts that are almost identical to those...
2" angle steel/square stock +1/4" plate... and a welder...
We'll see if I can get to it, feels like a ^$#&&*^ cold coming on, the weather supposed to be great.
Posted: Tue May 31, 2011 6:08 am
by mrblyoung
If you are interested in that pictures mount, let me know. I have one sitting out in my parts bin that came with my notchback buy. I actually added it to the metal scrap bin cause I had no idea what it was until now. It must have came off of the 901 that was included.
Posted: Tue May 31, 2011 6:26 am
by Munchhausen
Piledriver wrote:Hmmm.. That Porsche 911 front mount gives me some Bad Ideas.
Do it! Do it!
How sad and boring would be the world without a welder
dont forget the camera
Munch
Posted: Tue May 31, 2011 6:35 pm
by supaninja
And of nowhere....BOOM! Some manifolds for my gixxer throttle bodies
tomorrow I'm ordering some K&N filters and 1.75" couplers/clamps. All I need now is some slowtwitch cable linkage, does anybody know how to get ahold of him?
Posted: Tue May 31, 2011 6:58 pm
supaninja wrote:And of nowhere....BOOM! Some manifolds for my gixxer throttle bodies
PM him, he's probably busy
Uni makes some nice filters in that size range---Aircooled.net sells them, much better filter than a K&N. Cheaper too.
John has xtra-shorties as well.
Posted: Tue May 31, 2011 7:05 pm
by supaninja
I have PMed him twice about it already, I'll probably whip up my own cable linkage. I'll peep those Uni filters out Pile.
Posted: Tue May 31, 2011 7:25 pm
by Soul
Nice! Looks as if you took my advice from page 2.
Posted: Tue May 31, 2011 7:54 pm
by supaninja
Soul wrote:Nice! Looks as if you took my advice from page 2.
Way simpler then getting weld plates cut and this way I will be mounting the TB's ultra low
Posted: Tue May 31, 2011 8:38 pm
by supaninja
Pile- those Uni's look a bit too tall for me. here is the K&N filters I'm looking at
http://www.knfilters.com/search/product ... od=RC-2382
Posted: Tue May 31, 2011 10:18 pm
He has some REALLY short ones that aren't listed, or maybe they are "for" the solex carbs...
Regardless, Uni makes really short filters that will fit and won't sand your motor like K&Ns will.
I'd look into some 2" elbows for a little runner length... Too short kills tq and you should have room.
Put the filters in an airbox in the center with a large cold air feed, then size really won't matter
(That's what I'm planning, anyway)
