Actually you wouldn't need shims for that, you'd be cutting the jugs and pushrod tubes down ~6mm./side.tonyorlo wrote:Another random Q.
I've been thinking about Pistons, from what I understand a 2l stock 94mm piston has a pin height of 36mm, and a 1.8 should be 42.5mm going by the 202.5 total length. My question is, could I use 2l pistons with my 1.8 crank/rods and then have shims machined to 6.5mm(or whatever it needs to be when I assemble it) to make up the difference?
Also, I think I've deceided to have Jake balance the bottom end, but before I send it to him would I be a moron by trying to lighten the rods a bit myself? Im not planning on going nuts, but it seems like a lot of weight could be lost on the stock 1.8 rods.
Good luck getting that cooling tin on, might be easier than going wider though.
Leave the rods be.
They can be lightened quite a bit by folks who have done it and have a big lathe and the tooling, and likely destroyed in an instant if you eyeball it with a grinder.
Theres like one place in the Dallas/Fort worth metro area that supposedly could rebuild rods properly...
RIMCO would have been a LOT cheaper, including shipping, and done a better job.
Decent bolts would be my priority. RIMCO can set you up with both if you desire (for a price of course), fusername was looking for a source of reasonably priced good stock-replacement bolts awhile back but I don't recall if he ever found the source.
They should have the big ends re-sized when the bolts are replaced, at least.
