Budget 100x71 Build
Eddie010
Re: Budget 100x71 Build
Post by Eddie010 »
cal 67 wrote: ↑Mon Jan 18, 2021 4:09 am
Eddie010 wrote: ↑Sun Jan 17, 2021 10:39 pm Hope you know, but you switched nr 1 and 2. Rod nr 2 is cilinder nr 1
Lol! They're just laid out that way to show the stamps on the rods! Still though, all the stamps should face the pulley side.
Ok no problem. :D
I find the forces drawing and the way to place the tangs interesting.
In one of the books I found that the tangs should face up.. but in other books they say it does not matter...
cal 67
Post by cal 67 »
😅 I just noticed what you meant. Those number markings were from the guy that sold me them secondhand. It doesn't matter, as I don't even think he balanced them. I have a balancing jig for various rod styles on the way. A guy made it for me - T1, T2 2.0L, Honda, and Chevy big end attachments, and 22 and 24 small ends.
cal 67
Post by cal 67 »
Think my #1 bearing's thrust interference is too tight, messing with the radial clearance. I need to investigate. It's not spinning as smoothly as I'd like. The bearing measured fine in the saddle.
Think I put this gear backwards 🤔. Thought that raised area was a built-in racer spacer....nope.
cal 67
Post by cal 67 »
Check Everything! The #4 exhaust lifter hanging up on a casting bump after the thrust bearing:
Did some quick filing, and got some needed clearance. I'll do more later. Just need to do cam timing and see where my decks are.
cal 67
Post by cal 67 »
JFats808 from thesamba gave me this tool years ago: it's one of the best tools I have - just a stock lifter with a half pushrod epoxied in.
Case is closed up now.
twodollardoug
Post by twodollardoug »
What did you use to seal the case halves?
cal 67
Post by cal 67 »
twodollardoug wrote: ↑Thu Jan 21, 2021 5:52 am What did you use to seal the case halves?
Nothing. I'm only mocking it. An engine should come apart and go together at least three times before it's complete.
twodollardoug
Ya, I thought you were done and closed it up.
cal 67
Post by cal 67 »
If you're going to use these pistons, make sure you point the scribed-in arrows toward the pulley. The short side points up on 1 and 2, and down on 3 and 4.
I'm going to figure deck and trim these guys. Looks around 5mm.
cal 67
Post by cal 67 »
Cut my 48 intakes down to 44. Manley doesn't have a single groove Type 4 valve smaller than 48 for the intake. It's pointless to have a 48mm intake valve unless you're up in the 280+ horsepower range. I'll clamp the barrels down and figure what I need to cut tomorrow. The offset side of the piston points to the top of 1 and 2, and down on 3 and 4, so the arrows need reversing for VW apps.
Really good news: a nice guy sent me some Pauter rockers. They may go on this. Not sure yet.
The lower head studs are shorter than the tops. They're just not screwed down.
cal 67
Post by cal 67 »
Pretty sure my LSA is 112° 😕. It's advertised as a 106°. May not be a bad thing though. I'ma do more investigating later. I want the majority of my power to be from about 4K-7.5K. You think 112 is fine?
Oh, I was mistaken about the loss of lift. My cam is lifting .429" at the lobe, so it's accurate in that aspect.
Clatter
Post by Clatter »
Love the details.. Thanks for sharing.
Those rods have an offset?
Now that you have some extra room to the lifter heads, you could pick a bigger cam. :wink:
Looking forward to seeing lifts with the Pauter rockers.
Seeing as how the factory rockers lift so much less on the exhaust side..
Can't wait to see the heads. 8)
cal 67
Post by cal 67 »
Clatter wrote: ↑Tue Jan 26, 2021 11:03 pm Love the details.. Thanks for sharing.
I actually will be using a physically bigger cam because the lower lift will allow a larger base circle to fit on the blank. This Q is too much. 290° @ .050" is at least good for 9,000 rpm. Also, I'd need to set compression past 13:1 to get a decent psi. I expected it to fall short. Looking at the "N" cam now. I can set it to about 12.2:1 cr on pump fuel and it'll be happy.
cal 67
Post by cal 67 »
Anybody know how to pop this sensor out without damaging it? Thinking the only way is to grind it and punch it out.
ARP flywheel bolts arrived
Measured dome volume. 100mm piston, .106" dome height, the flat portion was .250" down the hole - 44cc. If I'm not mistaken, that's a 5.91cc dome.
cal 67
Post by cal 67 »
Spent a few hours today checking decks with all my pistons and cylinders. One of my case decks looks to be .0015" higher than the rest. Compression heights vary by .002"., and cylinders by .002". I guess some juggling is in-order after I cut down the barrels. When measuring each of the barrels on the table with a caliper (I'm pretty good at it), I get much different numbers than when bolted into the engine. I can't imagine why. No burrs, hang-ups, etc. I think the barrels' bores are not perfectly parallel to the exterior cuts.
Decided to go back to the P cam. I'll get a slightly larger base circle diameter this way, and have less .050" duration. Ideally, I'd like about 275°, but I'll settle for 280. A lot of Nords are finding success with this cam.
Waiting to weld my heads. Maybe this weekend...
