Hello everyone,
Have been reading the thread on the VSS and there is a simple and cheap solution I just built one using a stock 1999 sensor off the tranny that I had laying around the shop. Subarus have at least 7 factory speed sensors. I used the sensor off the tail shaft built a five fingered wheel similar to others pictured in this thread (ronW) made a bracket to mount the sensor to the tranny less chance of it getting damaged. total cost 0. have over 100 miles on it already and no codes.
Carb'd (Now EFI) EJ22 Into '69 Bug
- Prtexx
Re: Carb'd (Now EFI) EJ22 Into '69 Bug
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
67 VW roadster
84 Westy
H2OSB
Wow, great thread! As Joel knows, I plan to do this swap as well. I love seeing all of the issues ironed out. I have no desire to reinvent the wheel, I will gladly take your ideas from the END of the thread and get er done.
H2OSB
H2OSB
Zno
I know this thread is old, but i have to ask, do you still have the weber to ej manifolds? Ive been looking at making a set. figured id ask.
- danielzink
Zno wrote:I know this thread is old, but i have to ask, do you still have the weber to ej manifolds? Ive been looking at making a set. figured id ask.
If you make a set - make two and I'll buy one off ya.
Dan
- danielzink
And.
FWIW.
There's a guy over at the Samba that fabricated a set of Dellorto to EJ22 manifolds.
Doesn't look too difficult.
thread is here: http://www.thesamba.com/vw//forum/viewt ... highlight=
I know a couple of fabricators...I may look into it.
Dan
FWIW.
Dan
