Page 7 of 7
Re: New Intake
Posted: Mon Jan 20, 2014 1:09 am
by Kalle
Paul H wrote:Kalle wrote:The intakes are going on my 2332 E85/turbo engine later on. I will keep you all updated with regards to the results.
Best rgs
BB
Will you re mount the injectors inside or up top this time ?
As is, in other words on the inside. Unless you say I should not?
-BB-
Re: New Intake
Posted: Mon Jan 20, 2014 1:26 am
by Paul H
Kalle wrote:Paul H wrote:Kalle wrote:The intakes are going on my 2332 E85/turbo engine later on. I will keep you all updated with regards to the results.
Best rgs
BB
-BB-
If you want nicer low speed running then inside mount or high mount is probably better as the injector tip is closer to the inlet tract.
The outside mount has a longer tube so you can loose some spray pattern.
I tested all positions on a 2180cc NA and there was no noticeable change in max horsepower-400hp on E85 I don't think it really matters where you pump the fuel in
Re: New Intake
Posted: Mon Jan 20, 2014 1:30 am
by Kalle
Paul H wrote:Kalle wrote:Paul H wrote:Kalle wrote:The intakes are going on my 2332 E85/turbo engine later on. I will keep you all updated with
Thank you Paul.
To quote Tor Skinne;
there is no need to go for a turbo unless you aim for 600+
-BB-
Re: New Intake
Posted: Mon Jan 20, 2014 1:42 am
by Paul H
So you aim for 600hp ?
Re: New Intake
Posted: Mon Jan 20, 2014 2:04 am
by Kalle
Paul H wrote:So you aim for 600hp ?
From 479 with the old set up using a single TB a old Borg Warner turbo to 600 is not that far. But no, I do not aim for anything. I will rebuild the CE heads and in the meantime replace them with a set of CNC ported 044`s in order to use the same intake system as I`m using on my 1641ccm engine. I`m not done racing with the little engine so the big one will be a spare when the little one give up.
Best rgs
BB
