Page 7 of 16
Re: My chenowth 4lwd upgrades
Posted: Sun Mar 10, 2013 7:38 am
by fordfreak
It uses a spacer on one side.
Posted: Sun Mar 10, 2013 7:45 am
by CentralWAbaja
Good man...funny thing about pictures...doesn't look like there could be enough room there.
Posted: Mon Mar 11, 2013 2:42 am
by fordfreak
Posted: Mon Mar 11, 2013 4:49 am
by CentralWAbaja
Nice welding shoes
Those must help let the sparks out and not get caught inside? Good thinking
Nice work also!
Posted: Mon Mar 11, 2013 8:43 am
by JUSSUMGUY
Very nice! It's motivating me to add coilovers on the front of mine. Are your shock towers 1 1/4 or 1 inch tube?
Posted: Mon Mar 11, 2013 9:36 am
by fordfreak
Do it!!
I can work in sandals cause theres no sparks with tig! Ha I go straight to the shop after work so I I usually have sandals on. I need to start bringing a change of shoes to work. Ive had some close calls lol
Posted: Mon Mar 11, 2013 9:50 am
by Devastator
Are you going to add some sort of locking device to those pivot bolts?
Posted: Mon Mar 11, 2013 10:01 am
by fordfreak
Ya im gonna make little hex inserts that fit into the head and bolt to the bushing housing.
Something like this but nicer
http://www.pacificcustoms.com/mm5/merch ... iling-arms
. I will be welding the nut on the other side
Posted: Mon Mar 11, 2013 4:52 pm
by fordfreak
JUSSUMGUY wrote:Very nice! It's motivating me to add coilovers on the front of mine. Are your shock towers 1 1/4 or 1 inch tube?
1 x .120 dom
Posted: Sun Mar 17, 2013 4:11 am
by fordfreak
So, I concluded I had about 11" of front travel with 4" arms and 10" shocks. I had major tie rod to frame clearance issues especially on lock to lock.
I decided I am going to notch the bottom tube a little bit and cut out the top tube where the tie rod cycles. I will add a tube almost 2" higher and bring it to the inside about 1". This will give me 15" of travel in the front. This ghetto remedy is gonna bother me the entire time I have the car, but my hood will cover the madness and I'm eventually building a new frame later on anyways.
Here's a little paint brush description of what I mean...
I made these flanged nuts for my trailing arm pivot bolts. I am going to weld them to the bushing housing.
Oh and I picked up my new hood on Friday! Ordered through Stewart Raceworks in Santee, CA. They acquired most of the Chenowth original fiberglass molds. *Still trying to locate the side panel molds.
This thing is really nice quality and super light!
**One problem though. My rack hits the hood. The hood sits about .750" too high in the front. I'm going to notch out the hood and if it looks like crap I will just put a little glass hump over it.
Posted: Sun Mar 17, 2013 4:25 am
by Getrdone
Sweet! I thought I was the only ridiculous early riser! In shop by 4!
Posted: Sun Mar 17, 2013 4:50 am
by fordfreak
Posted: Sun Mar 17, 2013 4:55 am
by fordfreak
Getrdone wrote:Sweet! I thought I was the only ridiculous early riser! In shop by 4!
lol negative. I'm up cause I work graveyard shift! The fab shop is just hobby stuff. I go in about 9am on my days off. ha
Posted: Sun Mar 17, 2013 6:22 am
by Getrdone
The engine sits about a half inch from centerline on a bus trans in relation to drive flange center. So, you can offset the trans to have a centered engine. Or center the drive flanges and have a 1/2" offset engine. I prefer equal axles and nobody notices a 1/2" on the engine.
Posted: Sun Mar 17, 2013 7:12 am
by fordfreak
Sweet, thank you for clearing that up. I thought something like that.
I centered by flanges between the stub axles. The distance cup to cup is 21 3/8". Should I take off 1/4" or 1/2"? I keep reading different things. This is gonna be funky axle length.
