Page 7 of 11
Re: 2058cc Build
Posted: Tue Jan 21, 2020 6:13 pm
by V8Nate
When I go to Google and type in "black rubber trim seal for fender flares" and go to shopping it comes up 2nd item down that link might work better for you
Re: 2058cc Build
Posted: Wed Jan 22, 2020 6:15 pm
by VIPERGREEN76
I found it on Euro ebay. I was looking in the USA seller only ebay. Thanks 8)
Re: 2058cc Build
Posted: Wed Jan 22, 2020 7:39 pm
by V8Nate
You betcha
Re: 2058cc Build
Posted: Thu Feb 13, 2020 4:19 am
by V8Nate
Update time, engine electrical is completely, exhaust and o2 installed, fuel filter/regulator installed. I'm currently going through the carbs and have 2 sets of idf's, one has f7 emulsion tubes and the other has f11's anyone know which is better? This weekend will be break in time I'm so excited! ImageImageImageImage
Re: 2058cc Build
Posted: Thu Feb 13, 2020 5:17 am
by V8Nate
Not sure what happened with the pictures. LolImageImageImageImage
Re: 2058cc Build
Posted: Thu Feb 13, 2020 1:29 pm
by Kafer_Mike
Nate - Looks good, again. If you haven't done it, you may want to check the rod angles and connection points at the carb as it will impact the distance and rate of 'throw'. I ran the same bell crank linkage and had to redrill the mounting points on the linkage arms/idle stops so the carbs remained synced from idle through full throttle. Also, I had the ball-ends on the upper side at the bell crank to lessen the rod angles.
Re: 2058cc Build
Posted: Thu Feb 13, 2020 2:51 pm
by V8Nate
Thanks Mike I'll definitely be getting it as close as I can its actually for kadrons but didn't feel like buying yet another linkage.lol I have a few idea's on how to modify it to make it better so far its pretty even and both carbs hit wot at the same time but the angle on the ball joints isn't the best but far from binding
Re: 2058cc Build
Posted: Thu Feb 13, 2020 6:48 pm
by saltracer
F11s are better on the street, use those.
Re: 2058cc Build
Posted: Thu Feb 13, 2020 7:12 pm
by V8Nate
Thanks Saltracer:)
Re: 2058cc Build
Posted: Sat Feb 15, 2020 9:54 pm
by V8Nate
Its alive! Rebuilt the carbs, made some "jet doctors", primed the oil and fuel systems and had my dad over to turn the key for me. Ran it up to 3100 for a half hour and couldn't help but blip the throttle a few times on the second video:) I've got a couple oil leaks I need to seal up, install the inner valve springs, re-adjust the rockers and put the rest of the car together to put some miles on it! It sure was nice to hear it run after all that work:)
https://youtu.be/kOfJDRgspM8
https://youtu.be/a1wuzSgQLVk
Re: 2058cc Build
Posted: Mon Feb 17, 2020 1:13 pm
by V8Nate
Started installing the dual springs, this tool makes it nice:) heres how the fuel lines turned outImageImageImageImage
Re: 2058cc Build
Posted: Wed Mar 25, 2020 9:53 am
by V8Nate
Hope everyone has been staying safe and healthy with this coronavirus! Well I finally had my first drive around the neighborhood and I am very pleased even though it needs to be tuned I love the eagerness to run this motor has:) I tried making my own air filters but they must be to restrictive cause it would barely run and just billow out the black smokeImageImageImageImageImageImageImageImageImageImageImageImageImageImage
Re: 2058cc Build
Posted: Wed Mar 25, 2020 10:00 am
by V8Nate
Heres the first drive
https://youtu.be/HnP3kdz9zlg
Re: 2058cc Build
Posted: Wed Mar 25, 2020 10:26 am
by V8Nate
Re: 2058cc Build
Posted: Wed Mar 25, 2020 12:17 pm
by Kafer_Mike
V8Nate wrote: Sat Feb 15, 2020 9:54 pm Its alive! Rebuilt the carbs, made some "jet doctors", primed the oil and fuel systems and had my dad over to turn the key for me...
Looking and sounding good, Nate! How did you make the 'jet doctors'? Just some copper tube and o-rings? I've considered adding the kits from CB to my IDFs, but never got around to it
