250HP+ 1600DP Mouse Motor
buguy
Re: 250HP+ 1600DP Mouse Motor
Post by buguy »
I just thought it would be fun to see what it would do with ice.
rubenski
Post by rubenski »
In that case, let us know!
I would make a box on top of my A2A intercooler and get a big layer of dry ice on it. That would be for drag racing. If I ever get to that point
Guess I will have to break a gearbox first
buguy
Post by buguy »
Breaking a gearbox shouldn't be too tough!
Passatman
Post by Passatman »
buguy wrote: Sun Sep 22, 2019 1:38 pm I run a Flex fuel sensor in the return line. I can't imagine ever getting a change in readings so drastic it would ever hurt the engine. Unless you were running straight E85, then stopped and added 87 octane, then did a launch control race the second you started it back up. I think the most fluctuation I've ever seen in a tank has been .2 of a percent.
Also I can't imagine running a Holset in a mouse motor. Unless it was all out drag racing. Any sort of street use that would have to be a lag monster! Once it came on it would be a wild ride for sure!
I wanted to mention too, at least for me, a 4x6 barrel cooler is working great for me. I think I gave $80 for it new on eBay. Of course I'm not pushing the amount of air the other guys are. I will be lucky to see 220hp at max boost (although I'm shooting for 250hp)!
Ok for a dead head system where would you run a flex fuel sensor or is it that this system doesn't use the flex fuel sensor.
MarioVelotta
Post by MarioVelotta »
Passatman wrote: Wed Sep 25, 2019 5:26 am Ok for a dead head system where would you run a flex fuel sensor or is it that this system doesn't use the flex fuel sensor.
In a dead head system, it would have to go before the fuel pump or high-pressure side.
[email protected]
Passatman
Post by Passatman »
Mario do you know if any of these flex fuel sensor is made by GM ( part number if available ) and if they are readily available. I would like to use one with a MS3X system.
Post by Chip Birks »
Get on ebay and search GM flex fuel sensor, you will get a bunch. They are good. Made in china, just like everything else. New in box, multiple styles available. Find the one that suits the hole you are jamming it into. Should be less than $50.
Passatman
Post by Passatman »
Chip thanks a lot.
MarioVelotta
I finally decided to hand my engine project off to a local engine builder. With all the little issues that kept popping up I was frustrated and getting nowhere quick. And just like that, there is forward progress again! Heads have been chopped, as of yesterday the geometry is being set and my header and new Bergman fan shroud are awaiting the new longblock so I can finally get this journey wrapped up! 8) 8)
[email protected]
Clonebug
Post by Clonebug »
Oh Yeah!!!!!!
The heat is on!!!
How big were the chambers as cast?
MarioVelotta
Clonebug wrote: Wed Feb 26, 2020 10:35 am Oh Yeah!!!!!!
The heat is on!!!
Yes, it is!
Chip Birks wrote: Wed Feb 26, 2020 10:35 am How big were the chambers as cast?
That is what the sharpie is, what I measured originally. They are now ~43cc
[email protected]
Clonebug
Post by Clonebug »
MarioVelotta wrote: Wed Feb 26, 2020 10:42 am
The heat is on!!!
Yes, it is!
What's your deck and final compression going to be???
With a deck of .050-.040 you should be around 9.0-9.4:1......
Must be going to run one o those BIG cams..... :shock: 8) :wink:
MarioVelotta
Clonebug wrote: Wed Feb 26, 2020 10:54 am What's your deck and final compression going to be???
It will just under 9:1 with the edges of the chambers rolled over. Not a big cam, similar to the one I had in my 2L.
[email protected]
buguy
Post by buguy »
Love the Porsche cooling. So much more room!
