Conversion Flywheel question
The Fix
Jake I ordered a 210mm Conversion Flywheel #10008 #16630 (order #127) from your online store and I was sent a 215mm Flywheel. My question is will that flywheel work with my 74 type I transmission and will I have to modify the bell housing?
I have now exchanged my 210mm PP and disk for a 215mm set and would prefer to keep the 215mm set up.
Any help would be great.
Thanks, Jon
Thanks, Jon
- sideshow
Hey, that is my flywheel! http://www.shoptalkforums.com/viewtopic ... highlight=
I was sent the wrong model 215mm.
The Fix
MASSIVE TYPE IV wrote:Ray, actually they were 7mm, even more odd than being 6mm!
I had to have a run of 1000 of the 7mm bolts made of grade 12 material just because no one had any that were better than grade 2..
Hey I am not complaining, just trying to see is I will have any problems down the road when I go to install it. I still need to get those bolts as mentioned in my other post.
Thanks, Jon
The Fix
Thank you Sir you are a gentleman and a scholar.MASSIVE TYPE IV wrote:Send an email to Rebecca
[email protected]
Specify that you need the 7mm units, not 8mm.
- dstar5000
This is strange! Last week, my 210PP bolted right up to the
forged 215mm FW off of a Wasser!
I dint think that a 210PP would bolt up to a 215?
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- sideshow
That is weird; the 215 bus PP will not bolt up to a wasser 228mm (Forged) or a 2 liter 228 Bus (cast).
I measure the hole spacing on 228 (cast & forged), Porsche 215, and bus 215 PP. Each one is different; nearest I can tell nothing interchanges.
9 1/4" bolt circle 228mm clutch
9" PCD 210 (or I think that is what it is)
9 3/8" PCD 215 Porsche
