plisss help
drmuelitas11
plisss help
hey..i have a type 4 1.8 and i want to knoe how fast would my manx be with it...also di i need mod the tranny??also i need da fastaest way to make powr at least 150 hp out of a type 4
- dstar5000
Re: plisss help
That would depend on the gear ratios in the tranny and the highest RPM that you would feel comfortable turning the engine.drmuelitas11 wrote:hey..i have a type 4 1.8 and i want to knoe how fast would my manx be with it...
I don't know! You dint tell us which tranny you GOTS!drmuelitas11 wrote:also di i need mod the tranny??
Fastest way? NOS, of course!drmuelitas11 wrote:also i need da fastaest way to make powr at least 150 hp out of a type 4
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
drmuelitas11
- dstar5000
Yea, you're gonna have to put a gland nut bearing in the flywheel
of the Type 4 engine.
I figure you can get 100 MPH out of it, easily.
Don
Don
drmuelitas11
- dstar5000
I wouldn't drive a Manx at over 100......
IF you are running 28-29 inch tall tires, 85 hp might just get you there.
Don
Don
drmuelitas11
well its not exactly a manxx its based on a manx chassis but i designed it and it has pretty big rims...its also hardtop and closed with a tubular chassis so its light but not super light i figure like 1300 pounds without driver ...i just want it to run as good as it looks....but i was thinkin bout a turbo, wut is a good turbo for da car and da max psi i can put??oh and thanks for ur help...
how do i post a pic?? so u can see??
- dstar5000
YOu have to have the pic already on the web somewhere:
Like this one:
http://www.bcl-manly.com/914_fan.jpg
You don't see the pic because it is not within an IMAGE quote, like this:
Now if I put the URL inside the IMAGE quote, you can see the pic:
Good luck!
Don
Like this one:
Good luck!
Don
