78.4 ?
Santas Brother
78.4 ?
Post by Santas Brother »
Jake: where did the 78.4 mm stroke come from ?
All other sizes are in whole mm sizes.
Seems like a strange number.
My guess is that is the max stroke
that will clear the stock base circle cam.
Yes,no ?
Thanks.
tuna
Post by tuna »
Actually the 78.4 stroke is a holdover from the Type 1 days. Why that particular number, I don't know. I think it may have started with the Okrasa cranks, but I could be wrong.
Tuna
R2.0
Post by R2.0 »
IIRC, it is what one winds up with when a crank is offset gound to Chevy bearings.
R2.0
1972 Karmann Ghia Convertible
"As God is my witness I though turkeys could fly." - A. Carlson -
Kelley
Post by Kelley »
Deck height?
Post by MASSIVE TYPE IV »
actually it came from Oettinger in the early days of VW stroking... I used to remember the story but I had to "Recycle bin" some of that old memory to make room for the new stuff or my brain would have locked up from overload!
Santas Brother
90 x 78 = 1985
90 x 78.4 = 1995cc
If you were racing in a class with a 2000cc limit,
some people would want that extra 10cc.
Yes, back in the day the 90mm NPR piston kit was very popular in the 2.0 class and used with this crank
Wally
Post by Wally »
MASSIVE TYPE IV wrote:Yes, back in the day the 90mm NPR piston kit was very popular in the 2.0 class and used with this crank
I think it is more likely that the 90,0mm Oettinger Nikasil cylinders/Mahle pistons were used for that size 'back in the day', but I'am talking type 1 here :oops:
The Oettinger type 1 Nikasils were 90,0mm, not 90,5mm, so thats rather distinctive :wink:
(the porsche 2,7 911 engine has 90,0mm alu barrels as well :roll: )
Walter
Here in the states the 90mm NPRs were very typical with the Type1. I used these all the way up to 1993 when the supply dried up.
Locked
