78mm stroke x 90.5mm bore engine combo
- Ephry73
Jake,
I spoke with you last week about building an engine for the Ghia, and I have come acrossed a cheap 78mm crank(type 1 journals) and some stroker rods(Ibeam), and was wondering about getting the rest of the parts I need to assamble a longblock with what I have. It may not rev as high as the newer 2liters, but I think this will be a good foundation for somethng bigger when I have more cash.
What cam do you recommend I get to suit the smaller valves of the Q heads? I am keeping the 39.3x33mm ones with very minor port work. I don't plan on revving it too much, but should be interesting to see what I can come up with.
I will still need to get from you cam, lifters, and such.....
Just curious.
E
Just curious.
E
Eddie Brown
LOL! I bet the 90.5*78 would be fun!Ephry73 wrote:Me crazy? nah bra. Just a cheap bastid.![]()
Hehehe
Hey Eddie, how's the 2600 coming along?
E
I've finally begun to put TIME into it. I've been cutting to length my CM head studs. Then I'm going to finish mocking up the top end. I still have to lap the cast iron clunckers to get a better seal. Then I'll take it all apart again and take everything in for balancing. Still some road to travel...
I hope the bad weather (flooding) hasn't affected you out there. Here it's pretty muggy and hot bro.
Late,
E.
- Ephry73
I'm thinking it will be a good foundation for other things, once I get it setup. Right now money is very tight, but I have enough parts laying around, and things, that the 78x90.5 will be cheaper to make than a stock two liter, or to rebuild the stock type 1 engine. All I need to do now is sale the CFI to make extra cash for everything else, and I will be covered.
There is always the possibility of a 2258 or even a 2599 if and when money comes. For the time being, the 2006 will be a good snappy little motor for the Ghia.
Glad the floods didn't affect you much. I have heard nothing but crazy things with all the water we're having.
E
E
- slowtwitch
- bj
E,
how are you going to deal with the pin height of the Pistons? 90.5b pistions have roughly the same pin height as a type 4 94mm stock piston correct?
there was a guy (billisgr8 i think)that put in 94b type 1 pistons on his stock type 4 2.0 bottom end and didn't have to shim the barrels too much for deck height.
i don't have the measurements on me right now, but i remember reading that there was a difference.
was this the crank that was on sale on thesamba too?
bj
bj
- Ephry73
The very same crank. Well, I will be building a 2258. For the money and parts I have and time, it makes sense. The rest is getting sold. I am now selling the CFI kit(again) to finish some things, and pay some bills. This will give me some peace of mind as well. With the difference I will get the 2258 engine built. Nothing fancy, but better than a stock 2 liter, and more torque than the 1.7 for sure. The Q heads I will send for boring and new guides, and just leave the valve sizes as they are until I can afford better heads.
The CR will be high, so I need to watch out for the deck height. Since I will be using type 1 rods and 96mm 22mm pinned pistons, I should not be too far off. Shimming is definitely required, but I will get to that path when I have the parts layed out and mocked.
E
E
Santas Brother
Eddie Brown
