I discovered the other night that the wrist pins for my 2316 do not go into the connecting rods when applying hand pressure, or even light hammer blows.
Do you recall offhand if these wrist pins are press-fit, or do I need to hone the small ends to get the wrist pins to fit?
They should go through with only light pressure by hand. Are you working in an air conditioned assembly area? I have found that the bushings are very dependant upon temperature and sometimes feel tight when sitting in A/C...
Checking pin fit is part of our prep service and generally we find that the bushings are spot on. Is this one rod, or the whole set?
