I tested it and revised it all last summer and had excellent results- it cools almost identically to the standard DTM as fas cylinder head temps are concerned. Only a few internal changes were needed from the original shroud, amazingly enough!
After bringing the 914 version to the market earlier this year I decided to make a kit that used a similar shroud with the deleted oil cooler housing because of space limitations on our Turbo engines as well as for a cleaner look that some customers ask us about from time to time.
This kit is virtually the same as the standard DTM, it uses the same surround tins, but it only deltes the oil cooler housing and feed tube, REQUIRING an external oil cooler to be ran.
The cost of the kit is 50.00 less than the current DTM kits stage basic-level 4!! It works great and looks great very similar to a stock shroud, much more stock looking than the original DTM and to some people that matters..
Here is the backside without the cooler housing
We have one in stock and these will be inventory items at the Type 4 Store from now on.
BTW- these are NOT available in carbon fiber.
