DTM in winter time
MetalSlug
DTM in winter time
I was reading through the stuff on the aircooledechnology site about the TI DTM. I'm going to be getting a more than mild 1914 TI motor built by Chico and was considering the DTM since I've heard and read good things about it he installs them on the motors as well.
My question is, I live in the outskirts of Los Angeles and the temps in the winter time can get down to the 40's at night. I've read good things about the cooling of the DTM, but as I read on thesamba, most people who use them have show cars and probably won't drive as much. Mine will be a daily or every other day driver (only time I won't drive it is when it rains).
I read on your site that if you simply switch to a non-doghouse fan, it should help in the winter when it comes to engine warm up. I don't know what would be considered "too cold" where I would have to change out the fan, so I just wanted clarification.
- doc
- Site Admin
40 degrees! Man, you left coast guys have it tough. Talk to the air cooled crowd in Minnesota. 40 below!!
I know Jake has talked about changing to the smaller width fan if cold weather and DTM combination kept things too cool. Once your DTM is set up, changing fans is literally a 10 minute job. Much better setup than stock. Couple of bolts and the whole alternator, alternator stand, backing plate and fan just pull right out. This is a nice feature of the DTM setup.
However, I'll be surprised if the "cold" temperatures in LA are going to warrant any changes. For most of us, you're just talkin' sweater weather.
doc
doc
MetalSlug
Haha, I knew someone was going to rag about LA weather. I don't live anywhere near snow, so its cold to me!doc wrote:40 degrees! Man, you left coast guys have it tough. Talk to the air cooled crowd in Minnesota. 40 below!!
doc
500LbGorilla
My engine has used the DTM in zero temps. The oil temp will not be too cool, at least not for long. The pressure springs in the galley should take care of oil warmup. You could run a power pulley in the winter if you need it to warm up faster and keep a little warmer.
If you have a stock engine, you do not need a DTM. If you have a bigger engine that has more heat and power output, it is a great option.
- Class 11 streeter
500LbGorilla
MetalSlug
Thought everyone said its a 5-10 minute job with the DTM500LbGorilla wrote:Fan easier than pulley? Ya think? Man, I think I'd rather change the pulley. No alternator stand bolts, no gen strap, no removing carb linkage, no backing plat bolts, no shimming the fan, no removing the fan nut.. a pulley nut and a crank nut.. piece of cake to me.
But hey, it's up to you.
I have been spoiled by the Type 4 shroud..
The Type 1 is a bit more work.
The Type 4 doesn't even need the generator stand removed, pop off the belt, loosen the strap, loosen the fan and slide the alternator out easily.
Changing the pulley ratio will effect the engine in different ways than swapping the fan.
