Windshield
Posted: Mon Nov 06, 2006 5:26 am
by TxFordGuy
For you guys that have a rail, how do you guys mount your windshields?
Posted: Mon Nov 06, 2006 5:42 am
by Leatherneck
I have mine secured with 8 screws with countersink washers, using the bugpack windsheild gasket.
Posted: Mon Nov 06, 2006 5:56 am
by scott the viking
Mine leaks
Posted: Mon Nov 06, 2006 8:59 am
by Leatherneck
scott the viking wrote:Mine leaks
Scott I hear they have medicine for that.
Posted: Mon Nov 06, 2006 9:18 am
by scott the viking
Yeah...but then it makes it blury.
Posted: Mon Nov 06, 2006 9:24 am
by MNAirHead
Anyone have a hinged system?
Posted: Mon Nov 06, 2006 9:46 am
by TxFordGuy
leaks, this is not on a bug, this is on a rail. its wide open. i'm just wondering about mounting. also, have any of you passed an inspection with just plexy glass. how mounting mount DOT Glass to a rail??
Posted: Mon Nov 06, 2006 9:56 am
by MNAirHead
Fed law is laminated glass.. plexi for sides...
My rail windshield is really leaky right now.
Posted: Mon Nov 06, 2006 10:06 am
by Leatherneck
TxFordGuy wrote:leaks, this is not on a bug, this is on a rail. its wide open. i'm just wondering about mounting. also, have any of you passed an inspection with just plexy glass. how mounting mount DOT Glass to a rail??
The leak thing was a joke. I had plexiglass at one time but it scratches easy and the thought of hitting something and shards of plastic coming through made me do it with DOT glass. My windshield was probably on the high end at $98 including gasket. Also put some rain ex on it also, it helps.
Posted: Mon Nov 06, 2006 11:20 am
by scott the viking
Apparently not a very good one.
Posted: Mon Nov 06, 2006 2:37 pm
by TxFordGuy
So you have DOT glass, bolted to your rail correct? Does the rubber gasket act as a cushion? And does the rubber gasket help so when you tighten the bolts it does not crack or break. i ask is because i can just see me putting this glass on there, go to tighten down the bolts and it shatters.
Posted: Mon Nov 06, 2006 2:58 pm
by Leatherneck
I first time I took it out in the dunes did some jumping bone jarring (for me) whoops and windshield held in great Second time took it out and wore goggles, sand and glass do not mix.
But back to your question. The screws go through the rubber gasket into the tubing, there is enought seperation between glass and metal so it does not touch, would only take once. Getting the template right before making the windshield is a must.
How are you mounting your windshield wiper or wipers?
Posted: Tue Nov 07, 2006 9:34 am
by TxFordGuy
havn't thought that far ahead, i was thinking on doing a temp setup since i don't want them on there except for inspection time. Do you get the holes drilled when you get the glass made or what?
Posted: Tue Nov 07, 2006 9:51 am
by MNAirHead
Leatherneck wrote:I first time I took it out in the dunes did some jumping bone jarring (for me) whoops and windshield held in great Second time took it out and wore goggles, sand and glass do not mix.
In most locales, hand crank wipers are acceptable.
