Hi all from a new member,
I posted this to the T3/Samba a while back but got no response...
AFAIU, the enclosed breather T4 as per a '80 Vanagon is somewhat of a problem for T1/upright conversions.
Would this engine create any problems fitting in a T3, a notch specifically? I searched and read about the square ports and stuff.
Is there anything elese specific to these engines that one should be aware of.
I think I'm able to pick one up, recently rebuilt for short money, as the van is rusted beyond repair.
thanx,
nikos
YAT4Q -- Yet Another T4 Question...
The enclosed breather is not an isue if you are keeping stock cooling, and the cooling system works somewhat better that any of the older T4 systems.
The only real downsides are it will have hydraulic lifters, and will have lived a sad, brutal life, spent entirely pushing a 4500 lb shed and it's contents down the highway at extralegal speeds, always headed uphill.
(At least the case in the USA. Elsewhere, YMMV)
Have the heads gone thru/seat replaced at a very minimum.
