no spark
volky68
no spark
Post by volky68 »
I just replaced the generator with an alternator on my 68 bug and when I try to start it it turns over but doesn't start.
Battery is new, I have checked the voltage to the B+ terminal on the alternator and everthing looks good. I checked the voltage coming into the + terminal on the coil when the ignition is on and it's hot.
I pulled the #3 spark plug wire and tested it to see if I had a spark, but no dice. I double cehcked all my wiring to make sure I had no loose wires and everything checked out ok.
What should I check next?
Could it be the coil?
MedicTed
Post by MedicTed »
You have power to the coil, but what about the ground side? It almost sounds like you lost the ground to the coil.
Speedy Jim
Post by Speedy Jim »
Look on my web site for:
"Why won't my engine start?"
Scroll down to "No Spark" section for a step-by-step.
Speedy Jim
http://www.nls.net/mp/volks/
The wiring for the Coil should look like this:
