Turn signal question
allsierra123
Im looking for small flush mount turn signals.To mount under the headlights on a bugeyed nose.I would like to use the LED style.The only ones I can seem to find are the ones for bikes only trouble with those they are kind of small.Think I would have to much trouble with the cops running a set of those?
- Leatherneck
allsierra123
- Leatherneck
http://www.dmv.ca.gov/pubs/vctop/d12/vc24952.htm
Visibility Requirements of Signals
24952. A lamp-type turn signal shall be plainly visible and understandable in normal sunlight and at nighttime from a distance of at least 300 feet to the front and rear of the vehicle, except that turn signal lamps on vehicles of a size required to be equipped with clearance lamps shall be visible from a distance of 500 feet during such times.
allsierra123
- Leatherneck
allsierra123
